Im in the process of building a pair of aleph2's... When I power up I get +43VDC across the output.
After 3-4 mins R16 (220k) eventually gets so hot it breaks down and smokes.The same thing still happens if the I disconnect the output boards from the main board so I guess the problem is with the main board? Any pointers as where to start faultfinding would be good. Otherwise I guess Ill recheck all the components again :-( |
#2 |
Welcome to the forum pythagoras,
I'll keep my congrats till your Aleph2 is fixed. Aleph2 you say? R16 220k? Are we talking about the base resistor of Q4? Not that it matters for the smoke, but it should be 150 ohm Please explain and give some more details. /Hugo |
#3 |
...Thanks Netlist, your right R15 was the resistor I meant not R16.
Found the problem... Q2 was dead (shorted)??. Changed that now everything works fine |
#4 |
congradulations on solving your problem.
Waiting to see your finished amp. |
#5 | |
But that's probably what you meant? /Hugo
| Aleph2 pcb's, matched fets for aleph2 and aleph ono pcb's | MemphisJim | Swap Meet | 1 | 23rd September 2005 07:15 PM |
| Aleph2's FS | harvardian | Swap Meet | 1 | 14th October 2003 01:58 PM |
| What's the difference between original aleph2 and DIY aleph2? | chris910 | Pass Labs | 3 | 17th August 2003 09:03 PM |
| Yet Another Aleph2! | kenny_(00)_ | Pass Labs | 21 | 6th July 2003 08:17 PM |
| CL 60 for Aleph2 | jeclk | Pass Labs | 1 | 21st October 2002 10:10 PM |
| Page generated in 0.07332 seconds (72.81% PHP - 27.19% MySQL) with 10 queries |
