L'Fake - A Cheap- A** Expedient to Replace the Elusive SIT
Old 23rd December 2012, 08:50 PM   #81
Bigun is offline Bigun  Canada
Bigun's Avatar
Originally Posted by Antoinel View Post
Electrons boil off the Wolfram wire, form a mobile sheath/cloud around it, and contribute to its classical solid state resistance. A hypothesis maybe that hot electrons may impart a "better" sound than cold ones meandering through a luke warm wirewound or Carbon composition power resistor.
I think you'd better lay off the egg nog :
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 23rd December 2012, 09:15 PM   #82
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
The light bulb definitely imparts one characteristic - in the midrange the
filament has a resonance which creates a slight bump to the output.
Interestingly, many years ago I was puzzled to see a Julian Hirsch
(Stereo Review for you tadpoles among us) review in which the Levinson
ML-3 amplifier had a bump-up in the midrange. Now I realize that perhaps
they were trying to simulate the light bulb.
I like the lightbulbs. They are cheap and contribute an organic quality to the
whole enterprise.
Old 23rd December 2012, 10:30 PM   #83
Antoinel is offline Antoinel  United States
whole enterprise.
Thank you Mr. Pass for the information above, and thank you Bigun for responding. I'll have egg nog tomorrow. What if the incandescent light load [wrenchone's or that of Rothacher's V.1 SIT amp] is the filament of a vacuum tube; for example KT88? Its cathode heater uses 1.6 A, and the tube has a maximum plate current of 140 mA. In a next step, I am in a position to bias this tube normally [wrenchone's +45 Vdc is/maybe ground for tube]. Apply a grid signal that is either in and or out of phase with that at the amp's input. Will this hypothetical setup work, and further influence the sonics of the parent amp [tube not biased]?
Old 23rd December 2012, 11:39 PM   #84
The one and only
I suppose it depends on the actual resistance of the heater. You are looking
for something on the order of 20 ohms.
Old 24th December 2012, 01:35 AM   #85
Thank you Mr. Pass. The heater voltage for KT88 is 6.3V pushing 1.6 A. By contrast, the dual heaters in 12AX7 connected in parallel require 6.3 V which pushes ~ 0.3 A to give a heater resistance of ~20 Ohms. Will a signal on its grid or cathode modulate heater current; due to proximity; also noting that the maximum sum current of its plates add up to a meager 2.4 mA? If this is possible, then one has an Active and Functional incandescent load.
Old 25th December 2012, 05:14 PM   #86
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
I have been thinking about using tube heaters as well! I have a very very large pile of non usable for audio tubes that need uses!
It's not about what you can BUY...It's about what you can BUILD!
Old 25th December 2012, 06:17 PM   #87
Lucky you; I only have four 12AX7s. I'll work with them this week and share the findings. Happy holidays.
Old 28th December 2012, 12:16 AM   #88
wrenchone is offline wrenchone  United States
wrenchone's Avatar
I checked out my hysteretic buck converter last weekend (I started up the circuit cold into a current source load and checked the inductor current vs. output voltage), and the performance (to me) was not acceptable. I basically want an ironclad current limit, but that's not happening, possibly because the hysteresis I'm programming is too small and the comparator is too slow. I have a possible solution for this, but before I discard the old design, I'd like to try a dodge where the programmed hysteresis is adaptive. In specific, I'd like to program a lot of hysteresis in cases where the input to output voltage difference is high - in other words, startup and overload/short circuit. In these cases, the output inductor of the regulator needs some time to discharge before the next switching cycle so that the output current doesn't ramp up out of control. I have a way to do this that I can hack into the existing circuit, and I might try it this weekend. It would be nice to get an acceptable solution with a crappy comparator like the LM393.
This is turning out to be interesting in the Chinese meaning of the term (may you live in interesting times...). There are no obvious single chip solutions I can apply to this problem, so it's up to me...
Old 28th December 2012, 01:54 AM   #89
Parasonic is offline Parasonic  United States
Parasonic's Avatar
Default This must be contagious
I have been working on this for a few weeks. The diagram isn't labeled for parts values but the tube is a 12K5 space charge tetrode and the setup is very straightforward. The sound was very good I thought, but this one was dismantled and another constructed in its place utilizing a 15CW5 and MJ15003 with a single 30 volt supply. When biased for 1/2 supply at midpoint you get the requisite 300 ma through the filament (heater). The sound is very good (to me). I worried about crazy feedback and/or regeneration effects possibly showing up but I can't recognize any sonic problems with this. Apologies to Pete Millett and his "Starving Student" headphone circuit. This was not intended to be a ripoff, I was just curious one night and it happened to work, before I stumbled on his circuit. I was looking for something "hybrid" for a table radio project that is ongoing. There is hardly anything new under the sun. Just posted this to confirm it does work. And works well IMHO.
Terry
Melody, harmony, timbre, rhythm
Old 28th December 2012, 04:56 PM   #90
Terry
Terry, It is contagious, and love the circuit you showed. I am also working on a circuit which I'll share ASAP. Kind regards.
L'Fake - A Cheap- A** Expedient to Replace the Elusive SITHide this!Advertise here!
If You Don't Have a SIT, Fake It... wrenchone Analog Line Level 93 30th December 2012 01:05 AM
Behind SIT 2 pdyn Pass Labs 0 13th September 2012 09:54 AM
SIT-1 and SIT-2 owner manuals Nelson Pass Pass Labs 25 12th September 2012 08:16 PM
WTB: 6.5" woofer to replace broken woofer in cheap band pass subwoofer Jimmy154 Swap Meet 2 5th October 2010 03:00 PM
The elusive Horn...can I have it all? Fast1one Full Range 13 5th October 2007 06:50 AM
Copyright ©1999-2017 diyAudio
