#51 | |
#52 | |
so , even in case of blackout , you're good nothing else than classic soft start , with bunch of NTC resistance instead of fixed resistors
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#53 | |
Go to www.ti.com Go to Products Go to Power Management Scroll down and to the right of the page. Find " Browse All Videos..." Scroll down the video list and find the title : Engineer it. How to do precision... I hope it'll help. |
#54 |
I have my own discrete switching solution - no steeenking chips! It addresses the problems both of current during startup and regulating down from a higher voltage. All the toroids I have in house will give me unregulated DC outputs of 55-60V. I have L'Fake Light running on a bench at work today with an outboard regulated supply (puzzling and enchanting my co-workers), and it appears to like a ~45V rail.
I thought of using a thermistor, but I still need to regulate down to a lower bus voltage. The switching solution I'm planning is reasonably simple and elegant, and since it also is current-mode, it inherently bucks out the line frequency ripple. |
#55 |
I might also add that I've been doing switching power supplies for a living for >30 years...
#56 |
#57 |
The switching regulator/current limiter is mostly built up, and I'm thinking of going in to work tomorrow to test it. When I'm more sure of things, I'll post a circuit.
#58 | |
My interest in Schade feedback as it pertains to bjts only, had led me to assemble the subject amp as shown in its attached diagram TCAwithFeedback.pdf. It is interesting to apply loop feedback around a current source amp [or transconductance amp; TCA] because this moves the parent TCA closer to a voltage source amp [VSA], and thus imbibes it with the added benefits of improved linearity, increased damping factor, etc. relative to the parent. Schade feedback in solid state systems seems to have the following requirements found in earlier schematics like those of wrenchone and others.
I'll characterize the performance of this system in the region 30Hz -150 Hz [the measurements will be reliable], and publish the data. Brgds. |
#59 |
wrenchone: Here are the promised results. Please note that I used a phase inverting TCA with a higher Gm [5A/Vi] than I reported above [1A/Vi]. This action made this application more realistic as this high Gm is like that of power MOSFETs and JFEts. Like before, I am not making any claims that this bjt power amp sounds like a vacuum tube, a SIT or L'Fake. Hopefully; this is only food for thought and a basis for further experimentation by DIYers.
Page 1 of the attached file [TCAwithFeedback2.pdf] shows the schematic which I used to generate the data shown in page 3. Page 2 is blank. The schematic is like the one shown above; except that I made a provision to measure voltages [the data] without and with feedback [switchable at Vf]. All of the voltages at the indicated nodes in the schematic are displayed in page 3. The input signal Vi from the Function Generator was not changed during the switchover. Here are the findings:
I'll assemble the second channel and do a listening assessment. Brgds. Last edited by Antoinel; 13th November 2012 at 07:33 PM. |
#60 |
I did a little messing around in PSpice this afternoon, starting out with a current source loaded Schade cell using Darlingtons. If there is no buffer, the distortion into a 10k load is about 0.3% overwhelmingly 2nd & 3rd harmonic . For grins, I tried tacking on my usual p-chanel jfet buffer in front, with the results shown here. I was surpised by the drastic reduction in distortion with the buffer in place.
Edit - in practice, I would use parts in the TO-92L package for a little extra dissipation, as I'm running about 25-26ma of current in the output Darlingtons. The ones I have hanging around are the MPSW45 and a Fairchild TO-92L version of the MPSA63. This might make a nifty little lineamp if you don't mind the signal inversion. Last edited by wrenchone; 13th November 2012 at 09:24 PM. Reason: practical thoughts |
| If You Don't Have a SIT, Fake It... | wrenchone | Analog Line Level | 93 | 30th December 2012 12:05 AM |
| Behind SIT 2 | pdyn | Pass Labs | 0 | 13th September 2012 08:54 AM |
| SIT-1 and SIT-2 owner manuals | Nelson Pass | Pass Labs | 25 | 12th September 2012 07:16 PM |
| WTB: 6.5" woofer to replace broken woofer in cheap band pass subwoofer | Jimmy154 | Swap Meet | 2 | 5th October 2010 02:00 PM |
| The elusive Horn...can I have it all? | Fast1one | Full Range | 13 | 5th October 2007 05:50 AM |
