Rough draft, modified SOZ with CCS pull-ups & CPU biasing, need advice.
Old 28th October 2003, 02:40 PM   #11
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
i don't understand half of this... but i think i'm inpressed?
i'd never heard of CPU biasing... a little more explanation for the
neophytes out here?
can't wait to see pics!
m.
Old 28th October 2003, 03:07 PM   #12
Brian Guralnick is offline Brian Guralnick  Canada
The processor basically does 2 things.
1) it acts like a volt meter. eg: in the main amp section, it will measure the voltage over the 2 speaker outputs.
2) after measurements are made, it will adjust the bias voltage sent to the 2 gates on Q1 & Q2 so that my output is 50% of the supply voltage & the DC voltage difference sent to the speaker is under a microvolt.
In the processor module, there is the potential to store the 2 bias voltages being sent to the Q1 & Q2 gates which will move slightly with amp temperature & age. Downloading this to a PC would give you a graph of your Amps consistency. Sort of like the little diagnostic memory capability in some car's fuel injection system microprocessor.
This concept is not completely new, there are some microcontroler biased tube amps which corect for drift as the tube ages.
_______
Brian
Old 28th October 2003, 03:10 PM   #13
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
And why so many bits in the ADC/DAC parts? Seems to me a simple microcontroller with integrated ADC/DAC will do the job. Well, maybe not grow lemons at the same time
Old 28th October 2003, 03:15 PM   #14
Default here is the psp...
Nothing special...
Here is the link to my pre-amp / attenuator PCBs.
http://www.diyaudio.com/forums/showt...002#post249002
Only the Balanced Zen Line Stage left, then I'll have made a complete system.
_______
Brian
Old 28th October 2003, 05:35 PM   #15
Microcontroller ADC are usually sufficient when taking multiple samples, however, I donít like their accuracy & drift factors. Compare this 4$ 4 channel switchable device: ADS1242
http://focus.ti.com/docs/prod/produc...Number=ADS1242
NOTE: my 2 audio in's go through a 1 Hz low pass filter.
For the dac, I figure 16 bit should be good enough. Something like this:
http://focus.ti.com/docs/prod/produc...Number=DAC8571
Can't use any dacs that need a maintained master clock since I want the processor board to shut down once the calibration is finished.
Now, the cheapest TI processor with 12bit internal AD = 3$, 14 bit internal AD = 7$. Cheapest processor is under 1$. None with a real DAC.
Now, from microchip, cheapest processor is < 1$, with 12bit AD = 2$, no 14 bit or above. None with a real DAC.
I figure using an 8 pin PIC12C508 with the 3$ 24bit ADC, and, 2 x 16 bit dacs (3$), for a total of 10$, it will kill the 7$ ti processor with the 14 bit AD before finding a 2 DACs for it.
_______
Brian
Old 31st October 2003, 10:21 PM   #16
Arx is offline Arx  Canada
Might want to have a peek at atmel.
Typically a tad bit more expensive than Microchip, but a lot nicer IMO. Much nicer instruction set, lots of registers, less funny issues with memory allocation and tables and stuff.
I'm definately far from being an expert on the things, but from the little bit I've done, I've found my favourite.
l8r.
Old 31st October 2003, 10:44 PM   #17
l8r.
Too later, the design is finished, look here:
http://www.diyaudio.com/forums/showt...957#post257957
_______
Brian
Rough draft, modified SOZ with CCS pull-ups &amp; CPU biasing, need advice.Hide this!Advertise here!
LED cathode biasing in push-pull input stage exeric Tubes / Valves 14 18th August 2008 01:35 AM
advice on an EL84 Push pull Amp schematic colin.hepburn2 Tubes / Valves 6 2nd June 2006 04:02 AM
Please advice on KT88 Push Pull Lucas_G Tubes / Valves 6 19th May 2006 04:37 PM
Advice on 6V6 push pull Parallel krzanik Tubes / Valves 4 28th March 2006 09:14 PM
Biasing Push Pull Triode amp into Class A G Tubes / Valves 11 4th November 2002 02:27 PM
Copyright ©1999-2017 diyAudio
