Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Pass Labs This forum is dedicated to Pass Labs discussion. |
#11 |
R.I.P.
Don't believe him !
regards Andrew T. |
#12 |
#13 | |
Hey ok thanks
The Le Monstre can work from 2x 12v car battery's i can see that working and that's a nice possibility. the JLH seems to be single rail but about 27v to power so... 2x battery's again which ill do if i have to. Quote:
Im actualy going to buy from ebay a broken Car amplifier you know the kind with large heat sinks 1000w amps etc as the chassis is perfect, I consider this a great idea as the terminals and all the plugs ill need will be already wired in too! Might as well make use of old parts! I can imagine probably the most wise solution would be using an amp that's Class A/B. but i have some kind of idea in my head that pure Class-A id like better lol and a more efficient amp for the sub woofer/bass... Last edited by Rixsta; 17th September 2012 at 01:18 PM. |
#14 |
the 10W JLH runs on lower voltage.
with a DC-DC converter you can have +/-40V if you like. siliconray have a 500W adjusteble sec and dual rail supply. something like that is good for 2ch F5. you can also use F5 with lower voltage and bias to make a mini F5 ![]() |
#15 |
Hi Rixta. It's not uncommon in car audio to install a second alternator and battery. That and an SMPS would give you whatever you want. My only thought was the comment that an F5 needed an hour to sound its' best. I am rarely in my car for more than an hour but that's just me. I think it's a great project. Good luck! Pics!
#16 |
regarding the warm up time. that is with passive cooling.
and you can't use that in a car ![]() ![]() |
#17 |
Thanks Audiosan! That makes perfect sense. I love the idea. Gotta find room for another alternator...
#18 |
Well thanks for the replys! i was originally planning on building something but interestingly i ended up with an already built DIY "Le Monstre"!
which i purchased from ebay, it will be interesting to hear how this thing sounds. i wanted to win it so i kept bidding right to the last moment ![]() Here it is 2x20 watts 12v Car Amplifier Class A, 2x20W (J .Hiraga schematic) no audison, brax, dls | eBay Any Comments ? ill have to see whats in it! I think ill also find or build a JLH and Mini-A some time too so i can compare and give feedback here. ill probably be running 8ohm speakers on the amps. I agree about the F5 needing time, however it seems to sound good within a couple of minutes of on time. As regard to the "20W Le Monstre" I just have one question i need help with, what kind of battery's should i buy ? it would be nice if they were not as big as a giant car battery. i should think i would have the amp on for 3 hours at a time max. usualy 1. then i need a good charging circuit to charge batterys from mains. for some reason i imagine having 2x series 6v battery's that's what my intuition tells me, but you can tell i don't really know what im doing yet lol for now ill run it from a PSU buy battery's later i think Iv'e not realy looked into how much this monster draws. Cheers Riki Last edited by Rixsta; 23rd September 2012 at 09:47 PM. |
#19 |
Was curious about those, but didn't know how noisy they were...if they were.
Thread | Thread Starter | Forum | Replies | Last Post |
Class A amp in car | shelter | Car Audio | 11 | 16th September 2012 10:36 PM |
Class D car Amp and Computer Powersupply? | icecoolwas | Class D | 3 | 27th October 2009 10:05 AM |
class-d pwm car amp | nicvoo | Class D | 1 | 12th July 2005 09:17 PM |
Class D car amp | audionutter | Car Audio | 7 | 16th September 2004 03:49 PM |
New To Site? | Need Help? |
