New to this forum and curious if anyone can identify this particular power supply setup for a Mini Aleph. I'm curious if this is a CRC configuration or just a juiced up version P2P-wired of the standard schematic. I have access to some cheap huge caps like these and interested to know if someone can see more clearly what this newb can't.
![]() Thanks. |
#2 |
no. this is no CRC.
aleph P1.7 pre. F5 power amp. CDpro2(need DAC). Vivaldi8 speakers |
#3 |
So it's just two (paralleled? in series?) 35000uf 40v caps instead of four 22000uf 25v caps suggested in the schematic?
Anything else that suggests to anyone that it deviates from the standard schematic? Thanks again. |
#4 |
i can't see what caps is on the boards that is up side down. but the two big caps in series is in paralell with the caps on the board.
aleph mini realy don't need that amount of caps. 6x10.000uF is more then good for 2 ch.
#5 |
if you are planing on building the mini aleph, then chipamp.com have som nice amp boards and PSU boards.
#6 |
Thank you.
| Mini Aleph Power Supply | Jack Tupp | Pass Labs | 21 | 11th January 2012 09:51 PM |
| Aleph Mini power supply | mike23 | Pass Labs | 5 | 9th October 2011 10:04 PM |
| Low cost compact power supply for sub-mini tube preamp | johnmac0117 | Power Supplies | 10 | 8th May 2011 09:48 PM |
| Using the same power supply for mini aleph and gainclone? | orpheus | Chip Amps | 3 | 13th December 2005 08:29 PM |
| Mini A Power Supply | harry303 | Pass Labs | 4 | 31st December 2004 01:41 PM |
