Project Aleph 5
Project Aleph 5
Old 14th September 2012, 06:47 PM   #1
deuze is offline deuze
Default Project Aleph 5
Hello everybody,
i want to try to build an Aleph 5 but i have a lot of question for a parts !
I want to build this amp with the schematics and pcb of http://www.kk-pcb.com/
For powersupply what do you think about this parts ...
link for schematics : ALEPH 5 POWER SUPPLY
Transfo ... http://www.amplimo.nl/images/downloa...ange/78057.pdf
Capacitor 22000uf... PANASONIC - ECOS1VP223DA - CAPACITOR ALUM ELEC 22000UF 35V 20%, SNAP-IN
ECOS1VP223DA - PANASONIC - CAPACITOR ALUM ELEC 22000UF 35V | Newark
Capacitor 4.7uf... VISHAY ROEDERSTEIN - MKP1839547164 - CAPACITOR AXIAL, MKP, 4.7UF, 160V
MKP1839547164 - VISHAY ROEDERSTEIN - CAPACITOR AXIAL, MKP, 4.7UF, 160V | Newark
Bridge Rectifier... VISHAY GENERAL SEMICONDUCTOR GBPC3506-E4/51
GBPC3506-E4/51 - VISHAY GENERAL SEMICONDUCTOR - BRIDGE RECTIFIER, 1PH, 35A, 600V | Newark
Choke... WURTH ELEKTRONIK - 744824622 - CHOKE, COMMON MODE, 2.2MH 6A
744824622 - WURTH ELEKTRONIK - CHOKE, COMMON MODE, 2.2MH 6A | Newark
Thank you for your answer.
Old 14th September 2012, 06:56 PM   #2
stoN_Cold is offline stoN_Cold  Serbia
stoN_Cold's Avatar
Better search for Brian GT PCB!
Regards zeoN_Rider
Old 14th September 2012, 07:59 PM   #3
Ok thanks i check
Old 14th September 2012, 08:00 PM   #4
AudioSan is offline AudioSan  Norway
use 50V caps. not 35V.
and 400VA transformer, insted of 300VA don't hurt
Old 16th September 2012, 12:27 AM   #5
slr 5000 is offline slr 5000  Australia
g,day
use the kkk pcb its a much better setup than the brian gt boards or peter d boards (i have all of the above )
more room for parts and the output devices space out way better on the sinks dissipating the heat better and allowing for higher bias /better sound ,they are very good boards
for the power supply go to aussie amplifiers and grab a pair of his psu3, they are already made and work perfect
i have been using the above with some nuvotem potted toroids for 5 years with no problems and if i had to build again i would do it the same
cheers
Old 16th September 2012, 12:38 AM   #6
how on earth can kk-pcb's board spread the heat better then chipamp's boards, with seperat outputboards???? it's the other way around.
regarding PSU. chipamp also got some very nice PSU pcb's. at a very good price.
Old 16th September 2012, 01:42 AM   #7
stoN_Cold's Avatar
KK-pcb's are low quality. Brians at least gold plated.
These are my:
Regards zeoN_Rider
Old 16th September 2012, 02:17 AM   #8
gold plated does not mean quality
layout thickness ect determins quality
as i said i have used all three pcbs mentioned ,have you ?
i owe nothing to any of the pcb makers mentioned i am just stating based on experiance which one is best
if you were building a head amp or one to be installed in a very small case then brians pcb or pd,s would be great
but for a full size amp the benefets stated in my first post can not be denied
i get the impression that seeing as you have the brian gt boards you will say they are the best regardless of if they are or not but i on the other hand have all three pcb,s and know which i would use
cheers
Old 16th September 2012, 02:56 AM   #9
i will also say that brin's pcb is the best one. and i have those. i also have kk-pcb's boards.
Old 16th September 2012, 03:00 AM   #10
Originally Posted by slr 5000 View Post
are you joking or what audio san
the output spacing on the brian gt boards is too close and does not spread the heat over a normal sink properly (being outboard does not make a difference)
it concentrates all the heat in a small area
the spacing and size of the kkkpcb boards spread the heat over a much larger area
i thought this would be pretty simple to understand
i will say again i have all the above boards do you?
where do you get this from?? wonderland?
yes 3 and 3 fets are a little closer. but wht bout the distance between the 2 3 groups? forgot that or what?
Project Aleph 5Hide this!Advertise here!
X Aleph Project Down Under macka Pass Labs 111 30th June 2008 02:55 PM
Aleph 2 project Thago Pass Labs 2 21st April 2007 08:44 AM
My aleph 2 project Jean Pass Labs 13 21st January 2004 08:14 AM
Looking for aleph project pictures. Andrej Introductions 6 1st March 2003 04:16 PM
Passlabs Aleph 5 project????? Chamberman Pass Labs 3 14th June 2001 09:53 PM
