Another Mini A Is Born
Old 25th October 2003, 10:51 PM   #1
Mark A. Gulbrandsen is offline Mark A. Gulbrandsen
Default Another Mini A Is Born
This project is built around a PCB graciously supplied to me by MikeW on these forums. This board is very well made with really good labeling for all components and connections!!
I wanted to keep this Aleph truely MINI so I went with just one pair of IRFP240 output devices, other parts are 1% mf Dale resistors, Panasonic electrolytic caps, and film type caps. A surplus but new Stancor P6434 filament trannny supplies 12.6 C.T. volts AC at close to 5A to the bridge developing around plus and minus 16 volts with one channel operating. A temporary pair of 27000@50 volts makes up the temporary filtration till smaller caps arrive. Heatsinks are fairly massive, but smaller versions, of the huge sinks I used on my 2's. and should suffice for convection cooling. With the chassis design I made up forced air coling would be a cinch if desired. A low RPM fan will blow air into the chassis rear and divert it to the bottom of each sink and then exit at the top.
Tommrrow I'll wire up the other channel and later this week post some photos and measurements of the unit.
Mark
SLC, UT
Old 29th October 2003, 03:10 AM   #2
I've now got both channels up and running. Its a neato little amp for sure. The Stancor surplus tranny is running a bit on the hot side so I've ordered a custom tranny from Victoria Magnetics.
Initial listening impressions are that its somewhat neutral sounding and has alot of the sound traits of the Aleph 2. Unfortunately my digital camera was stolen so pictures will be another few days in comming.
BTW: The tranny will be 160 va, dual 12.6 volt (about 6 amp) secondaries. John Snowden says he can make this size tranny quite small in keeping with the theme of the Mini Aleph.
Mark
Old 29th October 2003, 05:04 AM   #3
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
Sounds nice, except for the dieam thiefs
Mads K
Another Mini A Is BornHide this!Advertise here!
Another GC is born! mantisory Chip Amps 10 6th July 2006 03:35 PM
One more DIY TT is born livemusic Analogue Source 18 20th December 2005 09:44 AM
New Aleph30 born mpopovics Pass Labs 4 15th July 2005 06:47 AM
New DAC born mdlover Digital Source 8 10th July 2003 09:20 AM
New clone born king30 Chip Amps 5 11th March 2003 03:35 AM
