Aleph 3 standby mode, possible turn off - Page 3 - diyAudio
Old 11th September 2012, 09:50 PM   #21
mercc is offline mercc  Slovakia
Originally Posted by RS232 View Post
You measure DC on the same points where you measured the AC...
The thing is like this
220/240V inlet goes to transformer to the rectifiers (before the rectifiers you have AC)
From the rectifiers to the capacitors to the boards you have DC...
The only thing you have to do is switch the voltmeter/multimeter from AC to DC and check on the capacitor (positive(red lead) to ground (black lead) and from ground (red lead) to negative (black lead)).
The leads are from the voltmeter and not the wires on the amp.
I'm no expert on the Aleph 3 but you should have around 26VDC on each side of the capacitor bank.
Ric
Yes, Aleph 3 should have 25 VDC. One channel board close to inputs/outputs has connections "out", "v-", "v+", "src", the other board has connections "v+", "out", "src".
Old 12th September 2012, 09:19 AM   #22
Originally Posted by Zen Mod View Post
put 2K2/3W resistors across each cap bank (both positive and negative)
You mean put resistors accross each individual capacitor or some similar arrangement as in the schematics, but there seems to be more capacitors forming CRC filter.
Old 12th September 2012, 10:12 AM   #23
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
last ones , connected to amp boards
anyway - it seems that you have bigger problems with amp , so you need to sort that first
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 12th September 2012, 11:34 AM   #24
Yes, somewhere is problem propably, dont know where. Now the amp assembled without 22000uf power supply capacitors. Measured with voltmeter some contacts and earthing points on the outside of the amp, i think helped for a while but its a bit worse, i think it tries to find some sort of power or what.
Old 12th September 2012, 02:45 PM   #25
RS232 is offline RS232  United Kingdom
I see you don't have much electronics experience, probably is best to look for someone that can help you maybe an electronic shop in your area.
Or like our friend Zen Mod says...
Send it to me for proper disposal...
Old 12th September 2012, 03:22 PM   #26
I have put it on sale on local forum, maybe it requires more suitable conditions, i dont want do dismantle it, in fact im a bit afraid. DC plus and minus wires from rectifier were desoldered but i soldered it back. DC ground connection was not desoldered. Really i dont know what to do.
Old 12th September 2012, 08:28 PM   #27
Did you got my PM ?
Old 13th September 2012, 09:20 AM   #28
Yes, i received your PM yesterday about half an hour after PM from local interested buyer. Caps are changed to original ones, I will also include the Vishay caps and new IRF9610 also the original IRFD 9110. I will also include two printed reviews and power cord that was included with amp. Today morning I received another PM from local interested buyer, so propably Im going to sale it.
I think that after location change the transformer will propably regain its original 25 volts, as was renewed the original transistor, really dont know.
Old 13th September 2012, 12:02 PM   #29
The transformer DC voltage is now 25 volts, one channel has DC voltage about 21 volts, the original IRF 9610 that seemed functional unsoldered now seemed to be conductive on two pins, the previous seems to be unconductive on outer pins, so i soldered the second unused IRF9610.
Now thinking about some kind of problem around IRF244 power supply transistors.
Standby mode and speaker turn on delay together? TiGeRGuY Chip Amps 9 6th September 2012 07:55 AM
Standby mode for Aleph series... eclam Pass Labs 10 2nd April 2012 11:23 PM
Aleph-x standby mode yup Pass Labs 16 19th January 2007 01:59 AM
low power standby current mode for Aleph 5 Adrie Pass Labs 16 22nd January 2005 07:19 PM
Aleph-X standby mode (once again...) CheffDeGaar Pass Labs 3 3rd September 2003 07:03 PM
Copyright 1999-2017 diyAudio
