I was once told by a friend down in Florida that he wouldn't consider a DIY amp because it would not be UL approved. Without such an approval, if his house were to have a fire, not DIY amp related, his insurance would not pay the bill because he had a non-UL device plugged into 1 of his outlets.
Is this true?
_______ Brian |
#2 |
Wouldn't that only be a problem if the device caused the fire by catching on fire. If the iron burns through the ironing board, the insurance would pay, even though we call that stupidity. Now, if he has a clause or rider that says not to do anything stupid...
:)ensen.
Those who claim to be making history are often the same ones repeating it. |
#3 |
In Germany, he'd be right if you swap "UL" by "CE".
More to the point, the burden of proof would be reversed. It would be your task to provide proof it was not the non-approved amp that burned down your house. I consider this an impossible task as the insurance company can afford the better lawyers Renting out self-made (non-approved) PA equipment to people for years gave me some kind of headache sometimes.
#4 |
For a living I install projection and sound systems in movie theateres. The UL tag used to be looked for by alot of electrical and fire inspectors, but since the early 90's that seems to have somewhat become a thing of the past.....even in a public building. There are at least three major ratings orginazitions now and at least two of those now carry more clout than the good ole UL label once did.
As far as DIY stuff goes, there may not be insurance coverage if your home burns down doe to the DIY project going up in flames. However using a good quality metal enclosure is a good way to be able to easily show if the amp(or what ever) caused the fire or not. With a sealed off electronic enclosure the insides will probably look like clean and new proving that the fire started elsewhere. Also at least here in the states all home fires are throughly investigated by the local fire department and that finding generally carries more weight in a court case. There is one other simple method to alleviate any possible insurance problems and thats to leave your equipment unplugged when you're not around. If a fire starts the FD will notice that the equipment is not plugged in...assuming there's enough left for them to see. In most civilized areas the average house fire rarely gets out of control. Mark |
#5 |
A fire would not be problem, however getting the insurance to pay the value of your DIY project migh be another story.
If your equipment is built well and with the propper safegards you will not have an issue in the US. In canada that might be different, you should use CSA approved wire.
Jim W. |
#6 | |
_______ Brian |
#7 |
I don't know how much it would help to argue for your case, but
if you are worried, make sure you follow all safety regulations for mains wiring etc., document on paper how you have done this and take close-up photos showing the actual wiring and solutions. Oh, and don't forget to store these documents and photoes somewhere else than in your house. |
#8 |
The one and only
What amplifier?
#9 |
With properly breakered, or fused circuits in a home I think the chance is pretty slim of that happenning. The only situation I can think of is an old home that might still have alumnium wiring. In that case the insurance co. would blame it on the wiring not meeting codes, not the device being used. There are ALOT of homes that still have alumnium wiring in them!!!!
Again, usually the fire departments findings carry the most weight. I know two people whos homes had fires in them. Both parties insurance companies paid their claims almost immediately. In one case the fire was started by an electric heater being too close to a curtain, the second one was a car that had a leak in the fuel line. To my knowledge neither the car maker, rapair station, nor heater manufacturer was sued or questioned at all. Mark |
#10 |
BTW, not right on topic but, I have talked to firemen about
electrical hazards, not DÍY stuff though. The two most important thiings to do to avoid fire due to electric equipment are: 1) Always pull the mains plug of you coffe brewer whennot using it, just switching it off is not sufficient for many of these. 2) Always swicth off your TV set with the mains switch at the front, rather than just through the remote control. The fire department in my area did a advertisement campaing for this, and it turned out that TV-related fires decreased dramatically here compared to the rest of the country. (Me, I confess I am usually to lazy to follow this advice.) BTW, I also asked about the risks of PCs catching fire. He said that to their experience this was almost a no-proglem. They contain so much flame-protection chemicals that are almost impossible to set on fire. They told me they had attemptd a realistic fire-evacuation exercise (don't know the english term) at a local company. To add to the realism, they decided to set a few PCs on fire. They eventually had to pour about two litres of petrol into the case to finally get it burning. Your local fire departments mileage may vary, of course. |
| The joy of insurance claims:Need peerless CSX1452608 (x4) | KBK | Swap Meet | 4 | 3rd June 2008 09:26 AM |
| Home Insurance | scooby300 | Everything Else | 8 | 18th October 2007 10:18 PM |
| Which way to fire my sub? | Gorbee | Subwoofers | 24 | 12th September 2006 01:59 AM |
| Insurance for DIY | seangoesbonk | Everything Else | 1 | 14th July 2002 08:58 PM |
| Page generated in 0.13039 seconds (78.79% PHP - 21.21% MySQL) with 10 queries |
