#461 |
Impossible. No way the sea would part for a poor old man and a bunch of vagrants. The Egyptian elite, on the other hand.....
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#462 | |
Again this are just assumptions and it might as well be just like you said.
Stefano |
#463 | |
Now here B&W Group North America Service & Support - Service Manuals You can download the service manual for the 800D where it shows you the midrange drivers crossover, it's quite simple, a 2nd order electrical filter is used for both the high and low pass. This wont combat that peak in any which way, but it's suddenly vanished. Air brushed out so it looks better in the white paper? Or perhaps this was a prototype that had a notch filter. Either way we wont know. Every measurement of the FST shows that it contains this peak and almost every third party measurement of the 800 series show that this peak hasn't been notched out. The service manual shows that the xover doesn't have a notch in it either, yet it's gone in the white paper.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#464 |
Makes sense.
Curiosity, if the midrange by B&W is one of the most linear components for these frewquency range, why would it be so bad with resonance? B&W declares instead that the midrange was resonance free, meybe I read that wrong don't know! Am I right or you use the same FST for your own developments?
Stefano |
#465 | ||
You need to know or should know your reference voltage, industry standard is 2.83volts .. The graph posted looks heavily smoothed and i can tell from the reflective trace to where it starts to smooth out that the software is fudging the results. I can also tell you are knowledgeable but lacking hands on , based on your comments and interp of your own data , Hence your previous comments about impulse and step responses... I would suggest using less smoothing 5th ... I spent many years , many moons ago , doing such sweeps, indoor treated, mic distance from floor 1m/2m/3m/ and i can tell you it does not match anechoic nor GP, GP open field , or pit firing up is best IMO, it was impossible to see any accuracy indoors below 1K unless we had a mic distance above 3M from the floor ... Again if you wanted to know what JA would see, you had to duplicate their setup , before submission ...it's not going to look the same with , near field measurements, cutting , splicing and adding summations ... Quote:
Correct, wool batons and r19 thrown around the floor does help, but why bother when you can yank the damn thing outside .. I'm sure 5th will still hang on to his "belief's" .......
#466 |
AHAHAH!!! Woow...you guys are so knowledgable....
so my question for you wayne is: why JA was unable to match the B&W set of curves? and why does the speaker show such a coherent sound balance while looking at the curves the sound should be completely different from what you actually hear from these devices?
Stefano |
#467 |
Sound quality of any speaker is determined by more than a flat on axis frequency response curve. Its also what kind of distortion you are sensitive to..
Myself find B&W speakers hard on the upper midrange and top end, i did not find the 801's like that , but their other modules for sure. There biggest issue with their previous versions where the small modules. Testing had shown the mid range cavity has to be pretty large to absorb reflections with out dynamic compression, our reference monitors at the time had a pretty large cavity that housed the 6 inch midrange driver . Low and behold their revised versions (current) did have larger modules and larger drivers. I would not read into the measurements too much , without looking at the full picture, 5th did not post up the impedance magnitude and phase , interesting to see if there were any wrinkles presentand if not for marketing most would just use paper midrange drivers , much better, very natural sounding vs Kevlar. regards, |
#468 | |||
Well if I am wrong, then so are a lot of other people out there and who's designs must all be inaccurate and plagued with problems due to poor measurements. They aren't, though. Maybe things have changed. Zaph did write this on his website though regarding the topic and I think it's quite relevant. Quote:
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! Last edited by 5th element; 18th September 2012 at 01:09 AM. |
#469 | |
![]() Wrinkle at 3.5kHz, no surprise there. ![]() Frequency response + phase without the crossover. I don't really see why the phase angles through the impedance are important though. I didn't make any impedance measurements of the driver myself because the entire system is active, so I have no absolute need for them.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! Last edited by 5th element; 18th September 2012 at 01:12 AM. |
#470 |
Projecting 5th ...?
pretty Poor anology ( who is Zaph ?) I have done the test both ways , others have said the same , you on the other hand have not , yet you condemn what is being said .. Condemnation without investigation ..? |
| Output Devices ! | cloud | Pass Labs | 11 | 10th November 2008 11:37 PM |
| Xa-30, Xa-60 ? | jrsun | Pass Labs | 1 | 13th February 2005 10:55 PM |
| Output devices? | Mr Evil | Class D | 42 | 12th January 2005 02:18 PM |
| Little brother of the XA-200 available? (XA-150) | MEnsing | Pass Labs | 17 | 6th November 2002 05:37 PM |
