I have build last year a (basic) ZEN and Bride of Zen ampli/preampli.
Both are working perfectly. I would like to share te PCBs that I have designed for these realisations : The files are attached. Note that : For the Zen PCB: 1) The 0,33 Ohm resistor has been replaced by 3 x 1-Ohm resistor (one resistor can not be mounted, in order to reduce the power and the heat of the ampli). 2) The PNP transistor is a standard BD140 (in place of the MPSA92) 3) The PCB of the Zen amp has the size (and is mounted) to fit in the central "channel" of a common low-cost heatsink for (TO3 transistors). 4) Are NOT on the PCB : The output capacitor and the power supply. For the Bride of Zen: The power supply is not on the PCB. For both PCBs : - Reduce the size (at printing) to adjust on the composants dimensions. - Be carefull in the "mirror" symetry. Many thanks for this very good ampli. |
| Very basic: 22V to 12V AC | Mr.Mekulic | Power Supplies | 22 | 22nd December 2006 05:53 PM |
| DIY basic | Solve | Multi-Way | 1 | 3rd October 2006 10:09 PM |
| Amp6 Basic | Dennis Hui | Class D | 10 | 27th September 2006 02:27 AM |
| Help with Subs and Amp (basic) | Sedodes | Car Audio | 5 | 3rd January 2006 12:08 PM |
| A basic chipamp in a not so basic case. | waltson | Chip Amps | 19 | 24th August 2005 07:40 AM |
| Page generated in 0.06451 seconds (65.24% PHP - 34.76% MySQL) with 11 queries |
