Several of Q-s about Citation 12 MosFet Several of Q-s about Citation 12 MosFet - Page 2 - diyAudio
Old 9th December 2006, 01:15 PM   #11
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Why nobody ask about D3? It's very clever to put it there due to bootstrapped VAS.
Old 9th December 2006, 01:19 PM   #12
lumanauw's Avatar
Hi, Wputera,
Apa kabar?
The amp is designed for Vertical mosfet. The threshold is about 3.5-4V.
K1058 is lateral mosfet, the threshold is below 1V. You must modify the Vbe multiplier's resistors (R14 or R15).
Old 10th December 2006, 11:04 AM   #13
wputera is offline wputera  Indonesia
Okay Mr. Nelson, i will try to set the bias current. Thank you for your help.
Hai Mr. Lumanauw, kabar saya baik.
Thanks for your help too, I will modify R14 or R15. Should I increase the or decrease the value of R15 (10 k Ohm)? Thank you Gentlemen.
Cheers.
Old 10th December 2006, 01:19 PM   #14
lumanauw's Avatar
Hi, Wputera,
To reduce bias voltage in VBE multiplier, B-C resistor must have less value or B-E resistor have more value. (Perbandingan resistor B-C dan B-E yang dimainkan)
Old 12th December 2006, 01:42 AM   #15
Thank you Mr. Lumanauw. That's will solve my problems with my MF-CITATION 12.
YBU.
CHEERS,
Old 8th September 2010, 11:03 AM   #16
atcgreg is offline atcgreg  Luxembourg
Hi all fans of Citation mosfet12 .
I build one, sounds great, but I have a huge problem with HUM when hooked up to a preamp Sony TA E80ES When the amp is not connected to the preamp it is silent.
I have checked all ground connections on the amp seems all ok could it be that the impendance of preamp does not match the amps.
the hum is only when I connect the preamp .
Preamp it self connected to any other monoblok amp has no hum.
Please help!
Old 14th March 2013, 05:21 PM   #17
nrg2009 is offline nrg2009  United States
I wonder if anybody offers boards for this amp? It seems like a very rewarding build.
Old 4th October 2016, 03:39 PM   #18
Rafy is offline Rafy
Originally Posted by Nat Riscica View Post
Hello,
I am built the Citation 12 using the MPSA 42 & MPSA 92 for all the transistors used, and the IRFP 240 for the Mosfet.
He work great!
Thank you Mr Pass.
Nat
Hi Nat,
Did you make any changes to the value of r1, r2 and r12, within the set mps 92/42?
What is the value v rail that you use?
My plan will also use IRFP240 complementary. Your information will be very helpful to me to get a good sound on the amp that I will build.
Mr Nelson,
Thanks. I really appreciate your great masterpieces.
Old 9th October 2016, 03:52 PM   #19
Bangla H is offline Bangla H  Germany
Bangla H's Avatar
Default Mosfet Citation 12 by kramskee
Because the long time interest here about Mr. Pass work (on kitchen table) in early days....i bought these clever boards- two options possible.
For me a must build to listen an Oldie Amp .
12th September 2016, 03:36 PM
* #1271
kramskee *
Ranchu, I've just produced a set of baords for the citation mosfet 12, configurable as complimentary or quasi complimnetary separate output and driver boards. designed to fit a standard square extrusion. PM me if you're interested ......... you can see pics here on this thread
citation 12 mos fet
Several of Q-s about Citation 12 MosFetHide this!Advertise here!
Mosfet Citation 12 Sandor Pass Labs 2 30th January 2006 11:57 PM
CITATION MOSFET 12 project. beppe61 Pass Labs 0 20th December 2005 09:57 AM
mosfet citation 12 mr l Pass Labs 12 27th December 2004 03:22 AM
Mosfet Citation 12 build questions Rjones5296 Pass Labs 2 17th December 2004 03:53 AM
Pass version of Citation 12 (Mosfet) G Solid State 13 10th November 2002 03:18 AM
Copyright ©1999-2017 diyAudio
