I burned my Aleph 3! Please help!
Old 23rd October 2003, 06:11 AM   #1
Jesse is offline Jesse  Taiwan
Default I burned my Aleph 3! Please help!
Hello Pass fans,
I somehow burned my Aleph 3 clone few days ago.
Now the right channel outputs +24VDC.
I changed the 3 IRF9610 and 2 MPSA18.
I checked the IRFP244s. Seems to be good.
But still no help.
The voltage across R106 and R108 is now only 1V.
The voltage at the D-leg of Q103 is 3V.
The voltage at the G-leg of Q102 is 9V.
The voltage across Q105 is 3.5V
The voltage across Z103 is 4V
Could anyone help please?
Thanks!
Jesse
Old 23rd October 2003, 06:53 AM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Did you replace Z103?
Strange that you have 9V at the Gate of Q102
Is that measured with respect to ground?
/Hugo
Old 23rd October 2003, 08:01 AM   #3
john-china is offline john-china
john-china's Avatar
Default z103 was broken
i think so.
Maybe i should not be lazy again
Old 23rd October 2003, 08:21 AM   #4
Hello Hugo,
Yes, the 9V is measured respect to ground.
Thsnks Hugo and John!
I'll replace the Z103 tonight and let you know the results.
Jesse
Old 23rd October 2003, 11:17 AM   #5
I changed Z103 but no help.
What else could be wrong?
Should I change the MOSFETs?
Jesse
Old 23rd October 2003, 11:32 AM   #6
Netlist's Avatar
What happened that caused the amp to misbehave?
Assuming you have + and - 25V supply,
I still guess your problem is in the front-end.
There is not a lot that can break in the input.
Make sure you connected everything correctly. (Bad solderings, earth)
What's the voltage across the feedback resistor?
/Hugo
Old 23rd October 2003, 02:18 PM   #7
Hi Guys,
I changed the MOSFETs (all 4 of them) anyway.
Now the output becomes -24V???
Q106 is VERY hot in a few seconds after powered on?
What else can go wrong?
Jesse
Old 23rd October 2003, 02:26 PM   #8
Hi Hugo,
I did something with my preamp and after that the Aleph burned. So I also think the problem is from the front end.
Yes, the supply rails are +/-25V.
By the way, isn't there two zeners to protect the circuit???
Old 23rd October 2003, 02:37 PM   #9
5th element is offline 5th element  United Kingdom
5th element's Avatar
I had a similar problem when I built my power amps, all the components we fine but the thing didnt work. The problem was in the PCB there was a tiny tiny break in one of the tracks (you couldnt see it but measure it you could), this sorted out the thing sang like all the other 4 channels did. Anyway could it be possible that you have got all the components working but in the listening process you managed to burn out a track that wasnt etched verywell. My boards were my 1st so they had some discontinueties your mite be fine. Anyway just my $0.02.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 23rd October 2003, 03:33 PM   #10
Netlist's Avatar
Yes, the zeners are there to protect the diff-pair from overvoltage and spikes, but they also can break.
You'll have to check your connections IMO.
Be careful with mosfets and ESD. Discharge the PSU-caps before
soldering something in and out. There's a good chance that 5 to 10 V remains at them after you power off. Get rid of that voltage
or you might damage your new fets when soldering them in.
You could try to disconnect your output mosfets and only power up your front-end.
Work carefully, try to power up with a variac and yes, check the pcb for bad traces. (Can be very difficult)
Any pictures perhaps?
/Hugo
I burned my Aleph 3! Please help!Hide this!Advertise here!
HELP Aleph 5 is burned? zigo3 Pass Labs 5 20th February 2008 12:00 PM
Burned T-amp fixable? jaste Class D 1 8th November 2007 08:38 PM
Aleph 2 fuse burned and killed mosfet! Aerosol Pass Labs 3 16th November 2002 07:50 PM
Help - just burned a ZV4 channel miguel2 Pass Labs 9 24th October 2002 06:05 PM
Copyright ©1999-2017 diyAudio
