Old 22nd October 2003, 09:19 PM   #1
jonk is offline jonk  Canada
jonk's Avatar
Question The making of a 3Amp A5 monoblock
I’m finally going to put together my mono block Aleph 5’s. Because these will be running my Quad 57’s I’ve decided to change my plans from a Aleph 2. I already have a pair of 1000va 33-0-33 trannys and enough heat sink for the A2 as well as a bunch of 36000uf 40V computer grade caps. I just wanted to run by my plan by the more (much more) experienced for obvious flaws and to ask a few questions. Here’s what I was planning to do.
I plan on choke loading the tranny’s with some Hammond 15mH 4 amp chokes then feed a 36000 cap, then air cored 12 gauge 2.2 mH (a pair of course, one for + and another for -) in a separate outboard supply. In the main amps I’d have another 4 36000 uf caps. This should give me 29-30V rails.
Since I have enough heat sinking I was going increase the bias to ~3 amps. As I understand it (or don’t) in the Aleph 5, the removal of R19 doesn’t increase bias all that much due to its already high value (221K). Therefore I was going to change the source resistors to 0.68 from 1. I also have some Caddock 0.1ohm 25W I was going to use on the outputs.
So here are my questions.
Do I have change the value of R16 if I change the source resistors?
Are the 0.1-ohm output resistors close enough? The A5 has 4 parallel 0.47’s.
Are there any other changes I should make since my rails are going to be 4-5 V lower the A5?
Will 0 .68 source resistors get me up to 3A bias?
Can I use 100V Shockleys with a choke input?
Is my thinking flawed?
TIA, any input/tips/suggestions would be appreciated.
Old 24th October 2003, 08:54 PM   #2
Jaac is offline Jaac  Netherlands
Jaac's Avatar
any pic's ????? maybe ????
The right tool for the right job, a very nice Solarboat || Ready for a groupbuy ? CLick
Yet another monoblock Sch3mat1c Solid State 4 22nd August 2009 12:00 AM
The best DIY monoblock? christianlie Solid State 10 17th December 2006 01:56 PM
Making a muscular triode monoblock amplifier using P-P Eimac 450TH's rcavictim Tubes / Valves 22 21st March 2006 07:41 PM
a 71A monoblock Joel Tubes / Valves 30 30th December 2002 09:19 PM
Page generated in 0.07294 seconds (65.72% PHP - 34.28% MySQL) with 10 queries
