Compound Power Amplifiers - Page 3 - diyAudio
Old 11th September 2012, 06:58 PM   #21
I was not happy with the performance of the simple differential voltmeter which was based on power transformers as I described it earlier. It was inaccurate in the frequency range of 30 - 150 Hz. Instead, I assembled on a proto board a classical differential amplifier using a 741 Op Amp which I powered with 2 rechargeable 9 Volt batteries. The top part of the attached file CompoundAmp A4.pdf shows the schematic of this diff amp of voltage gain ~10. Its output fed the AC multimeter. The bottom part of the file shows the test setup for the Compound Power Amplifier [CPA] which I then used to accomplish the following objectives:
  • Calibrate the diff amp and the CPA components with 4 and 8 Ohm non-inductive power resistors [20% tolerance]
  • Measure impedance in the frequency range of 30 Hz - 150 Hz for the woofer in the A/D/S L-730 loudspeaker
  • Generate additional graphs which shed light and explained the operation of the CPA.
With the switch open [VSA isolated], I collected 17 data points for each of Vo, Va, Vsp, Vb [see test setup] as a function of frequency [30 -150 Hz] for the load [Z] of 4, and 8 Ohms resistors and the loudspeaker.
Results
  • Z = 4 Ohms: Va = Vb = 150 milli Volts. Average Vsp4 = 1.19V +/-0.3% . It was a straight line in the range of 30-150 Hz.
  • Z= 8 Ohms: Va = Vb = 150 milli Volts. Average Vsp8 = 2.48 V +/-0.3%. It was a straight line in the frequency range 30 - 150 Hz. Note that the value of Vsp8 was roughly double that of Vsp4 as expected.
  • Z =woofer impedance. Va = Vb = 150 milli Volts. The second attached file Compound Amp A4 Impedance.pdf shows the impedance of the woofer in the 30 -150 Hz range. The voltage Vsp [shown] mirrors exactly the impedance. I also superimposed the reference calibrators Vsp4 and Vsp8. A maximum impedance of ~9.4 Ohms was measured at the woofer's resonance frequency of 45 Hz. A minimum impedance of ~4.3 Ohms was measured in the range of 90 - 100 Hz.
The voltage gain of VSA in the 30-150 Hz range = Eo/Ei ~ 23
The Transconductance [Gm] of TCA in the 30 -150 Hz range was calculated as follows: Io = Va/0.5 Ohms or 150 mV/0.5 Ohms = 300 mA. Note that it is already amplified by the diff amp by a factor of 10. And Gm =300 mA/300 mV in = 1 A/Volt.
The first two objectives were met. To be continued...
Old 11th September 2012, 08:43 PM   #22
The attached file CompoundAmp A4 Impedance1.pdf shows two graphs which explain the individual operation of the VSA and TCA [30-150 Hz] in the Compound Power Amplifier. What is each amplifier doing as the impedance of the woofer changes with frequency? I collected 18 data points for Vo which is the output of TCA, and 18 data points for the Joint Output after the switch is closed to integrate them to CPA. Please note the definition of Vo and Joint Output per the setup schematic of the previous post:
  • Vo = Va + Vsp + Vb . Holds true for the stand alone TCA and for CPA.
  • Joint Output = Vsp + Vb only for CPA.
In the CPA, Fig. 2 shows that Vo was constant at an average of 1.59 V +/-1.5%, and the Joint Output was also constant at 1.44 V +/-1.4% in the 30-150 Hz range. By contrast Vo for the operation of the stand alone TCA followed the general shape of that of the woofer. The variable Vo of the stand alone TCA which tracked [and mirrored] the impedance of the woofer as a function of frequency collapsed to a constant straight line of average value = 1.59 V. Recall that in the "tuning" of the CPA, I adjusted the output Eo of VSA [switch open] to match [Vsp + Vb] at the frequency of minimum impedance. The intersection of the Vo curve due to TCA only with that of Vo in CPA happened as expected at this "tuning" frequency of ~100 Hz.
In the CPA, Fig. 3 shows that TCA was putting out a constant current as inferred from the constant voltage Va of average value = 150 milliVolts +/-0.4%. By contrast, the current [from TCA] flowing through the loudspeaker as measured by Vb across 0.5 Ohms in series with it was inversely related to the impedance of the woofer. At each frequency point of measurement in Fig. 3, the numerical difference between Va and Vb is the offset current that the VSA soaked up or siphoned off the loudspeaker. Why? Had the VSA not done so, the Joint Output would have violated its expected constant output of 1.44 V imposed by its intrinsic design.
I'll distill the learnings and conclusions in an upcoming post. In the interim, dwell on the results, ask for clarification if needed, and add your comments.
To be continued..
Old 11th September 2012, 10:51 PM   #23
Here's an interesting connection which came to mind. But first note that any gain device [including TCA] is intrinsically imperfect because the current flowing throught it and the voltage cross it vary as it delivers power to the load [paraphrase per Nelson Pass]. The answer to suppressing voltage variation is the technique of cascoding. As the impedance of the woofer varies, the voltage across the internal devices of TCA vary accordingly. In the CPA, the voltage variations [Vo for TCA only]are sequestered as seen in Fig. 2 of CompoundAmp A4 Impedance1.pdf above. The net result of Vo =1.59 V suggests that the VSA acted as a cascoding device to TCA. Thus, the intrinsic imperfection in TCA due to voltage variations across it is substantially reduced by this pseudo cascoding which is a plus for the overall performance of CPA.
Old 18th September 2012, 07:05 PM   #24
In posts 19 and forward, the TCA was the sole contributor of output current to the loudspeaker. I noted that some of this current was shunted by the VSA when the impedance of the woofer [as the working example] increased above its minimum value of ~4 Ohms at 95 Hz to ~9 Ohms at its resonance frequency of 45 Hz. Clearly, the VSA wasted "valuable" output power, and an attendant fraction of the sonic print of TCA. This maybe/is unacceptable. The numerical value of 4 Ohms above was preset with the 25 Ohm pot across the secondary winding feeding the VSA. This pot adjusted Ei and set the output voltage Eo of VSA to buck exactly the output voltage Vo from TCA. In the upcoming post, I will increase the value of Ei and hence Eo such that Eo bucks exactly the value of the votage Vo from TCA at the resonant frequency of the woofer of 45 Hz. In this new experiment, TCA is the sole contributor of current to the woofer at its resonance frequency. And will not waste any of its valuable current in the VSA as long as the impedance does not rise above 9 Ohms. But; and there is inevitably one. As the impedance of the woofer rolls downhill from resonance [on either side of 45 Hz], the VSA begins to contribute more output current to the loudspeaker; in effect diluting the contribution [and sonic print] of TCA.
To be continued..
Old 25th September 2012, 05:59 PM   #25
This is a continuation of post#24. The attached file CompoundAmp A4Fig1.pdf shows the working schematic for this experiment and its following procedure:
  • Open Switch and measure the voltage drop across the loudspeaker's woofer Vls as a function of frequency. Find the maximum voltage which mirrors the maximum woofer impedance at its resonance frequency; in my case at 45 Hz. Stay at this frequency and its maximum voltage.
  • Adjust the output voltage of VSA [Eo] with the potentiometer [25 Ohms] to equal the value of Vo'
  • Close Switch. The voltage drop across the loudspeaker Vls stays constant. This Compound Power Amplifier [CPA] is adjusted to continue this experiment.
The second attached file CompoundAmp A4Fig23.pdf shows the objective performance results. Figure 2 shows the voltage drop across the loudspeaker [Vls; woofer component] as a function of frequency [30-150 Hz] due to TCA only, VSA only, and the CPA [mating TCA to VSA]. The graph due to TCA only is a mirror of the woofer impedance in the frequency range. The maximum impedance occured at 45 Hz. Since the TCA is pushing a constant current through the woofer [I], the attendant power injected in it is: I x I x Z Watts. Clearly, this output power due to TCA only varies with frequency and generates a certain tonal balance.
The voltage drop across the woofer due to VSA only and CPA had a similar shape. This means the woofer is under the control of the VSA unit [for damping and %THD etc.]. For practical purposes, the voltage drop across the woofer in the test frequency range is much flatter than due to TCA only operation. The output power invested in the woofer by CPA has changed relative to that from TCA only operation. Thus, the tonal balance of the subwoofer must adapt and change accordingly. It did, and got louder by comparison with TCA only operation. Figure 3 shows the variation of voltage drop across the sense resistors [0.5 Ohm] as a function of frequency. This voltage drop [mV] mirrors the current flowing through the sense resistors. The voltage Va mirrors the current contribution of TCA only in CPA. It was constant at 136 mV in the test frequency range. The voltage Vb mirrors the current flowing through the loudspeaker [woofer] from the sum contributions of TCA and VSA. Note that Va = Vb at 45 Hz; because I adjusted it that way at the outset of the experiment. Thus the contribution of TCA to the current flowing through the woofer at 45 Hz is 100% [0% from VSA] and expresses its sole sonics. The VSA component begins to contribute current flow through the woofer on either side of the resonance frequency. The peak contribution of current from the VSA occured at the minimum woofer impedance of 95 Hz. This contribution from the VSA component was equal to the mirror value of 134 mV [shown as the symbol delta] . Clearly, the TCA and VSA in CPA each contributed ~50% current through the load. This 1:1 blend ratio is believed to express each of the individual sonic contributions of TCA and VSA in the same woofer. Thus, the varying impedance of the woofer has enabled 120 [150 Hz -30 Hz] different blend ratios with their attendant distinct sonic signatures.
The loudspeaker was louder at this adjustement [max impedance at 45 Hz] than at the previous adjustment of low impedance [earlier post at 95 Hz]. The sound of music flowing out the loudspeaker was fully satisfactory. The woofer region was pronounced [TCA contribution] and articulate . I need to do more listenning.
To do experiment:
  • Use a TCA of low output impedance [Zo]. For example; load the parent TCA [high Zo] used above with an 8 Ohm non-inductive power resistor [for example] to convert it to TCA'. Use TCA' only, and also with the same VSA to drive the woofer of A/D/S/ L-730 in experiments like I did above.
To be continued...
Old 26th September 2012, 03:09 PM   #26
Originally Posted by Antoinel View Post
To do experiment:
To be continued...
I d like to delay the above experiment in favour of the following one which is in progress:
  • Threshold S/150 is a stereo, and an ideal voltage source amplifier [VSA]. The right channel [Rch] will be used exactly like I have done in the above experiments. It has a low output impedance Zo of <100 milliOhms [or VSA-Zo0R]. By contrast, I inserted an 8 Ohm non-inductive power resistor [20 W] in series with the output of the left channel [Lch; or VSA-Zo8R]. Both channels were compounded as shown in the attached file CompoundAmp A5.pdf. This new diagram is like the other ones I showed in previous posts; except that VSA-Zo8R [Lch] has replaced TCA.
The SE Triode 300B amplifier is a VSA which is believed to have a Zo = 6.5 Ohms [or VSA-Zo6.5R]. How will a Compound Power Amplifier [CPA] using SET 300B sound at a Zo ~0 Ohms instead; which maybe close in value to that of a Futterman? Will VSA-Zo8R [Threshold Lch] be a suitable test model for the SIT amplifier of Rothacher which is a VSA of Zo ~8 Ohms? The forthcoming data will shed light on how the Threshold S/150 compounded amps work together, and hopefully predict the operation of others.
Old 12th October 2012, 05:11 PM   #27
Default A Compound Power Amplifier
Objective: Mate a voltage source amplifier [VSA] having a finite output impedance [for example 8.5 Ohms] with another ideal VSA having a ~zero output impedance.
Outcome: A Compound Power Amplifier [CPA] having an ideal ~zero output impedance and the performance of the VSA having the finite output impedance. Specific performance will follow as experimental data are presented.
The time is here to report the findings of the above experiment. I'll stream all of the information over several posts. Ideally, one may wish to print the attached files to connect with the text in the posts. The schematic in attached file CompoundAmpA5a.pdf is the same as the one in the previous post. Please note in this schematic the nodes [Vo1, Vo2, Vo3, Va, Vb, and Vsp] used to generate a graphical performance of the voltage source amp of output impedance equal to 8.5 Ohms or [VSAZo8.5R]. The loudspeaker is an 8 Ohm un-enclosed 15 inch musical instrument which is bolted to a joist of the ceiling in the lab. This speaker is still supplied my MCM Electronics.
  • Open Switch A to decouple the Right channel VSAZo0R
  • Power up the function generator and Threshold S/150.
  • Adjust Vi at the the input of VSAZo8.5R to get a differential voltage measurement Va ~100 milliVolts at a frequency of 150Hz.
  • Sweep frequency between 30 Hz and 150 Hz. Collect and tabulate voltage measurements.
The graphical data in Figure 1 show the following:
  • Vo1 is a flat line =3.48+/-0.004 in the frequency range 30-150 Hz. It means that the gain of the component voltage generator is constant which must be the case by its design.
  • Vo2, Vo3 and Vsp had similar curve shapes. This curve shape is like the impedance curve of any woofer; including this musical instrument. A peak impedance as mirrored by Vsp happended at 45 Hz. A minimum impedance occured at ~100 Hz. Their numerical values are not relevant in this experiment.
  • The loudspeaker impedance and its sense resistor [0.5 Ohm] are the sum load to VSAZo8.5R. The voltage Vo3 is taken to be the base performance of VSAZo8.5R and this load.
The graphical data of Figure 2 show the performance of current flowing through the sense resistors as mirrored by the differential votage measurements Va and Vb which were [and must be] equal. Minimum current flow happened at the maximum impedance encountered at 45 Hz. By contrast, the maximum steady state current of [103 equivalent mV] was found at ~ the minimun impedance in the range of 90 -150 Hz.
Do the following in the next step in preparation for closing Switch A to make the Compound Power Amplifier [CPA].
  • Keep the system powered and warmed up.
  • Switch A is still open.
  • Adjust the frequency of the function generator to 100 Hz. The voltage Vo3 is at its minimum because the the impedance of the load is at its miminum. The actual numerical value of Vo3 was = 1.65 V.
  • Adjust the external pot [25 Ohms] at the input of VSAZo0R [Right channel] to increase Eo so as to equal and closely match Vo3 [1.65V].
  • Close Switch A. The numerical value of Vo3 = Eo will hold at 1.65V.
  • Sweep the frequency in the range of 30-150 Hz, and collect all of the pertinent data.
The next post will show the performance of the resultant CPA by comparison with the base performance [above] of VSAZo8.5R.
To be continued...
Old 13th October 2012, 06:33 PM   #28
  • Insert resistor Rc = 0.5 Ohms between switch A and Vo3 to sense current flow in this branch.
To be continued...
Please note that I inserted the underlined in the above quote. The attached file CompoundAmp 5b.pdf shows the schematic of the CPA and Figure 1. The Right channel voltage source amp is consequently abbreviated as [VSAZo0.5R] because I inserted the sense resistor Rc in series with its output. I also removed Switch A which was a make or break connection rather than an actual switch.
The graphs of Figure 1 are the essence of the experiment.
  • They showed voltage measurements across the load [Vo3] before closing Switch A [due to VSAZo8.5R; call it base case], and [Vo3] after closing Switch A; or in the Compound Power Amplifier [CPA]. The change in Vo3 [mostly amplitude] from the base case to that of CPA was substantial. The impedance Zo at point Vo3 in CPA is now mostly equal to 0.5 Ohms which is the value of the sense resistor Rc.
  • They also showed the relative ranking of the voltage generators. let us focus only on the voltage values for the CPA only. The rank followed the decreasing order of Vo1>>Vo3>Eo>Ground. Here is the relevance of this rank. If for example these voltages were derived from DC batteries, then the flow of DC will drive down the same rank. Meaning that current flows in the branch from the higher to the lower voltage nodes by convention. This says that the voltage generator component of VSAZo8.5R is the "top dog", and consequently ditto for its output current. Also, Vo3 [CPA] is higher in value than Eo in the resonance region of the loudspeaker. This meant that node Eo is a current sink; more like ground.
The second attached file Compound Amp A5c.pdf shows Figure 2 which is attendant to Figure 1 from the same experiment. It shows a graphical representation of the current flow in the CPA. I'll stop writing here so as not to bloat this post, and talk about Figure 2 in the next post.
Old 13th October 2012, 07:52 PM   #29
Figure 2 in the file CompoundAmp A5c.pdf of the previous post shows the interplay of current in CPA as mirrored by Va ,Vb and Vc of Figure 1. The following are the key results:
  • The current [Va mirror] emanating from VSAZo8R was contant [across Ra = 0.5 Ohms], and had the highest measured value of 101 +/-2 millivolts equivalent. Its constant value meant that VSAZo8R was acting as a current source [albeit AC modulated]. Its high[est] value in the system meant that it was the sole current source or generator in the CPA; and thus there was no other current contribution from VSAZo0.5R.
  • In the resonance region of the loudspeaker [or woofer], the attendant current [Vb mirror] flowing through it was like the mirror or inverse of the speaker impedance [Ohm's Law at work]. One may ask; where is the balance of the current [constant Va minus variable Vb] going or gone? That is the measured Vc mirror sunk in VSAZo0.5R. Current accountability was not great in the resonance region [i.e. calculated versus measured]; but as Vb decreased/increased Vc simultaneously increased/decreased; and this was the relevant result. Beginning at 30 Hz, the constant current [Va mirror] pushing through the increasing impedance of the load would have increased Vo3 beyond the preset value of 1.65 V. Higher Vo3 values would have violated the constant gain Eo/Ei of VSAZo0.5R. Basically, this amp clipped this rising voltage [see the max Vo3 for CPA in Figure 1 at resonance] by shunting the current from the generator [excessive] which tried to force the voltage Vo3 to rise in the first place.
The findings in this and the immediate previous posts implied that the schematic and performance of the CPA under study were:
  • May be a useful guide to compound VSAs which have an intrinsic high output impedance with an ideal VSAs of ~zero output impedance.
  • The VSA of intrinsic high output impedance in the CPA is the sole contributor of output current/power in the loudspeaker.
  • The ideal VSA in the CPA is mostly accountable for its low output impedance.
Removed Rb and Rc for playing music; which was a fully satifactory experience.
Old 5th November 2012, 06:17 PM   #30
The two parent amplifiers comprising a Compound Power Amplifier [CPA] were electrically connected or joined with a metal wire in each schematic/diagram of the above posts. I discuss in this post the compounding of a voltage source amplifier [VSA] with a current source amplifier; also called a transconductance amp [TCA] by proxy of two identical full range loudspeaker drivers. My ears/hearing was the compounding avenue. This is absolutely one of the simplest compounding experiments that I've done; and fortunately with interesting consequences. The attached file CompoundAmp A6.pdf shows the working schematic. Here are the details in bullet points:
  • VSA is one channel of THRESHOLD S/150 of voltage gain Av = ~21. It drives the Right side loudspeaker.
  • TCA is one channel of a DIY TCA of Gm = 1 Amp out/volt in. It drives the Left side loudspeaker.
  • The amplifiers may be swapped; VSA to Left side, and TCA to Right side.
  • The loudspeakers are 15" musical instrument drivers sold by MCM Electronics.
  • The loudspeakers [~10 feet apart] are bolted to the ceiling joists of the semi-finished room such that they focus their output [angled] at a point on the floor which is the sweet spot for listenning.
  • The transformer is an AC Power Toroid described in an earlier post.
  • The audio source is Mono. I used the volume-controlled Right or Left channel of a CD player's headphone amp output.
  • I balanced or centered in my head the output of the loudpeakers by making Eo [from VSA] equal in magnitude to Vo [from TCA] at 1 KHz by using an oscilloscope. Basically each speaker's accoustic output power was ~ equal for voice. This was done by tweaking the 25 Ohm pot on the transformer's secondary feeding the VSA.
  • The power resistors [0.5 Ohm] in series with the output of each amp were used for sensing output current versus frequency [function generator sweep] . Removed them for listenning to music.
Each loudpeaker projected a uniquely different sound. The loudspeaker driven by VSA had a characteristic sound [solo] and the other loudspeaker driven by TCA [solo] sounded totally different. Said otherwise, each driver spoke differentely or carried different information e.g. of tonal balance, relative accoustic output, phase etc. My ears integrated their outputs. Their integrated bass output was mostly and strikingly different. This ensemble was very listenable in mono. Sounded more like listenning in stereo.
Melon Head and buzzforb: Imagine the above 15" drivers adjacent to each other on the OB panel which Melon Head will use for bass management of his new loudspeaker creation. Focus for a minute on the bass region spanning 20-150 Hz. One will get the simultaneous superposition of a least damped and a high accoustic output from one driver energized by TCA, and the highly damped, and maybe a lesser accoustic output from its adjacent driver energized by VSA. Clearly you already have the baselines: 2 VSAs driving two identical woofers, and two TCAs driviing the same two woofers. And the cross experiments. Which woofer is closest to ground; driven by TCA or VSA?.
Choke power supplies for Class AB Power Amplifiers - which Rules for Calculating ?? tiefbassuebertr Solid State 12 3rd November 2011 08:47 AM
Compound Lateral FET for higher power Class AB amp. Mooly Solid State 17 22nd August 2010 02:13 PM
Balanced compound-IGBT power amp idea revintage Solid State 10 21st January 2008 04:27 PM
Can i use a computer power supply to power audio amplifiers? destroyer X Solid State 91 25th September 2006 04:36 AM
Copyright 1999-2017 diyAudio
