One of my Zen Lights has died! - Page 9 - diyAudio
Old 16th September 2012, 02:56 PM   #81
Forgot to add, MOS input current is < 500 nanoamps. 20,000 ohms x 0.0000005 = 10mv drop.
Bipolar base current of 10's of milliamps will require much, much lower input resistor.
Old 16th September 2012, 03:07 PM   #82
Zero Cool's Avatar
What puzzles me the most is that these amps ran fine for months! then one day blammo! Maybe they have been running right on the edge and one the day of death the AC line voltage was just a bit high? I have been setting the variac right at 120V ac and maybe that's the issue?
It's either that or my other wild guess theory is that one of the caps in the ZL CLC power supply is funky and that is causing a spike at switch flip turn on? whatever the case is I am NOT turning on the other ZL with the good 040 mosfets until i have a 100% rock solid solution!
I emailed Nelson and asked (almost begged) him to look and see if by chance he has one more 040 left laying around. In the meantime I have another 20x 044's on the way...
BTW, what is the difference between the 044 and the 044N version? one has a lot lower input capacitance.
It's not about what you can BUY...It's about what you can BUILD!
Old 16th September 2012, 03:16 PM   #83
kevinkr's Avatar
Sounds like you might have been on the right track to begin with, a single moderately sized resistor on the primary with a timed relay would probably kill this issue with few other issues remaining to be resolved.
I've not experienced this sort of mosfet breakdown phenomena so far, but will keep it in mind for the day I potentially do.
If this is indeed the mechanism (and it seems possible) then the idea I suggested would tend to make it even worse..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 16th September 2012, 03:23 PM   #84
kevinkr's Avatar
<snip>
This is one of the things I alluded to in an earlier post, what if anything has changed?
  • Cold resistance of varistors lower than than when new?
  • New lower resistance line cords? (Lower IR drop during inrush?)
  • Plugging into a different outlet closer to main panel (Lower IR drop during inrush?)
  • New pole transformer, tap change? Line voltage marginally higher than before?
  • Changed power sequencing (did you turn them on together in the past causing more line sag and a slower dvdt at power up?)
It could be any of these things or none of them. A fun if somewhat frustrating challenge to resolve. (And moderately expensive)
Hoping NP has a few more of the original fets so that when you have this resolved you can use the originals which presumably perform better..
I'd stick the digital scope on the supply and try to figure out what is happening during the initial inrush phase.. Might not be a bad idea to also look at the gate so that you can determine the gate to drain voltage differential over time.
Old 16th September 2012, 04:19 PM   #85
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
as I wrote earlier - chain of NTC's , high value , delayed switch across them
that will solve slow ramp up of PSU voltage
all needed is additional relay and NTCs
additional relay coil either in series or parallel , with existing output relay coil
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 17th September 2012, 09:11 PM   #86
For MOS devices, breakdown voltage of drain to gate is the same as breakdown voltage of source to gate. Gate oxide thickness is same over drain, source and channel (substrate).
IRFP044N appears to be attempt to duplicate IRFP044 using newer processing techniques that results in smaller geometries to achieve same Ids and Vto. Thus smaller capacitance is due to smaller gate area with perhaps same gate oxide thickness.
IRFP4321 is an even newer technology achieving some improvements over 044 for Ids. I would theorize that gate oxide thickness is 1.5 x of 044. Gate oxide area would also be 1.5 x, resulting in input capacitance ~ 044 input capacitance. But the big reward is gate to source and gate to drain breakdown voltage is increased from 20v to 30v minimum. This is the device I would be using. Thicker gate oxide also increases Vto about 1 volt, from 2v - 4v to 3v - 5v. You will need to change R1 and R2 accordingly.
Looks like a IRFP4321 also costs twice as much as a IRFP044N.
Old 17th September 2012, 10:22 PM   #87
Zero Cool's Avatar
Thank you! that's some good info!
Old 18th September 2012, 11:36 AM   #88
Zero Cool's Avatar
I looked up those IRFP4321's and they have 4600pf of input capacitance! YIKES!
The 044N's have 1500pf by comparison and that is 500pf less than the 2000pf of the non "N" part and that's why they interested me!
Old 18th September 2012, 01:05 PM   #89
Compared to IRFP040, IRFP4321 has higher Cgs but much lower Cgd.
Cgs is specified at 0v, but in actual circuit the voltage is ~ 4v. This reduces capacitance.
More importantly, Cgd is less. Cgd x circuit gain = miller capacitance. Therefore, miller capacitance is less with IRFP4321. Total input capacitance is Cgs plus miller capacitance.
Besides, what does it matter? Your preamplifier is driving this input capacitance through 348 ohms.
You do the math. I'm getting confused.
Old 21st September 2012, 03:03 AM   #90
Zero Cool's Avatar
AHHHHHH HAAAAA we have answers! more than expected actually! TADAAAA
So my new tube of mosfets arrived today! I bought some NOS 044's and some 044N's First I used an 044N and placed a 15v zener from drain to gate and flipped the switch using the ZL power supply connected to the Bench Zen. and after a dozen switch flips, not a single mosfet failure. So to prove concept I disconnected the Zener and flipped the switch and BLAMMO dead mosfet instantly just as expected!
Then I connected a 044 and repeated the test and zener in, no failures. zener out....also no failures???? 2 dozen switch flips and not a single failure! So the 044's are MUCH tougher than the 044N's!
No combination of input or output shorts or power up cold, hot, supply drained, half drained etc etc etc produced a dead 044 mosfet! but if you blink wrong a 044N will blow up!
I can't leave the zener connected during operation as it definitely interferes with operation. and if I am going to redo the output relay circuit anyway. I can just add another relay that is tied to the speaker relay circuit that connects the zeners during start up and then after a few seconds disconnects the zeners as the amp is coming out of mute! this way the precious original 040 mosfets will be protected! No slow start needed, although it may still be nice to build a simpler version that allows remote start.
So I think I have the problem figured out and solved!
A big thank you to JamesBrennan4 for the D-G zener suggestion and generally for all the cool mosfet info! also a big thank you to everyone else for all the input!
Zc
Papa's Zen Lights are no slouch! Zero Cool Pass Labs 8 13th May 2012 09:02 PM
My Rotel just died hybridfiat Solid State 4 1st August 2008 01:33 AM
M DCX died, what to do? sqlkev Digital Line Level 3 22nd May 2006 07:03 PM
Need help--powered sub just died mouse Subwoofers 3 29th October 2003 02:18 PM
Has my monitor died? meta Parts 2 11th December 2002 06:03 PM
Copyright 1999-2017 diyAudio
