Juma's Preamp for F5 -new built- - Page 2 - diyAudio
Old 7th November 2012, 09:13 PM   #11
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Rs= 0R for Idss
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 8th November 2012, 07:19 AM   #12
GentryBa's Avatar
hi!
thank you all!
ok, now I know how to get Idss from them.
I will check that today in the afternoon.
Is it possible to change the value from P1, too? I thought, I read that in the preamp-thread...?
best regards,
matthias
Old 8th November 2012, 09:36 AM   #13
juma is offline juma  Germany
juma's Avatar
Originally Posted by GentryBa View Post
... Is it possible to change the value from P1, too? ...
Of course it's possible but I wouldn't do it before we know what are we dealing with. So, what's the Idss of JFETs that you have ?
Old 8th November 2012, 11:14 AM   #14
GentryBa's Avatar
Hi juma,
I have BL ones installed in my circuit. I didn't match them.
In the moment I can't do the measuring, because I'm at work.
I saw a pair of matched GR-types, will they do the job as good as the BL-types?
Thank you for your time to answer me!
Best regards,
Matthias
Old 8th November 2012, 11:29 AM   #15
post11
replace the Ammeter with a 100r resistor.
Measure the voltage drop across the resistor to determine the Idss.
eg.
Vr= 100.8mV, then Idss = 0.1008V/100r = 10.08mA +-accuracy of DMM, +-accuracy of resistor, +- the effect of error in Vds & error in Tj.
i.e. 10mA is close enough.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 8th November 2012, 12:14 PM   #16
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by AndrewT View Post
post11
you are suggesting to measure across a 100R drain resistor for both k170 and j74 ?
Old 8th November 2012, 12:40 PM   #17
juma's Avatar
...I saw a pair of matched GR-types, will they do the job as good as the BL-types?...
Not without changing some resistors.
There is no use in watering the subject down before you do the measurements...
Old 8th November 2012, 01:05 PM   #18
yes.
I don't understand why the question. Do you see a problem that I have missed?
regards Andrew T.
Old 8th November 2012, 01:07 PM   #19
post11
eg.
Even Bigger OOPS than usual !!!
1008mV across 100r for 10mA of Id.
regards Andrew T.
Old 8th November 2012, 05:57 PM   #20
GentryBa's Avatar
hi!
measuring (maybe correct ) done:
my "high quality" chinese devices have following values for Idss:
2SJ74 BL : from 4.7 to 6.2mA (3 pcs.)
2SJ74 GR: 6.2mA (1 pc.)
2SK170 BL: from 13.8 to 13.9mA (5 pcs.)
the N-types are from china (3pcs.) and from a german distributor called "reichelt" (2pcs.)
their values are very close together (if measuring was correct, then they would be higher then BL specification, I think?)
three P-types (guess which ones- the chinese ) have 4.7 to 4.85mA and should be "BL", the reichelt one has got 6.2mA and is a "GR" graded one.
changing one of the chinese devices gave me an DC-offset of 160mV, much better than before, but not really changeable if I turn the pot?
so, where can I get GOOD jfets for this preamp?
best regards- and as always- THANK YOU for helping!
matthias
Preamp ideas for F5 ejfud Pass Labs 474 8th November 2016 03:18 AM
Firtwatt F5 built - where to buy? CENTRAL Pass Labs 30 27th January 2012 06:08 AM
Preamp in F5 manual Beftus Pass Labs 2 20th November 2009 07:10 PM
wanted built aleph x or f5/f3 boards slr 5000 Swap Meet 2 12th March 2009 08:41 AM
i want to built new preamp maxpou Solid State 8 1st January 2008 08:11 AM
Copyright 1999-2017 diyAudio
