Juma's Preamp for F5 -new built-
Old 8th November 2012, 08:17 PM   #21
nr12 is offline nr12  Germany
Hello Matthias,
try zhoufang (here in the forum or on ebay), he is selling 2SK170 BL.
Or in germany try kessler-electronic. Ask for BL grade before you order.
Ulf
Old 8th November 2012, 08:33 PM   #22
juma is offline juma  Germany
juma's Avatar
GentryBa,
you are aware that some of your JFETs are out of specifications (4.7mA and 13.8mA can't belong to BL grade) which makes their other characteristics (gm, transfer curve) highly suspicious.
This preamp works on presumption that JFETs are a complementary pair without big differences in Idss (few mA is OK). Of course, there are ways to balance the input pair (no matter what you choose to use) but soundwise, it won't be worth the effort.
If I were you, I'd choose a preamp made with current production parts - the one with BF862 I like even better, this one too...
Old 9th November 2012, 09:59 AM   #23
GentryBa is offline GentryBa  Germany
GentryBa's Avatar
hi everybody!
@juma:
jepp, I know that they are massive out of the needed specifications.
problem is: I have bought everything I need for building it. (2x r-core transformers, capacitors, etc,etc,etc...)
I don't want to spend more money for new parts like transformer, etc... again.
In the preamp-thread, where you posted your layout, everybody said that it sounds very good- so I will hear it, too...
I think I will have a look at kessler electronic and ebay.
Old 9th November 2012, 10:14 AM   #24
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by juma View Post
....... the one with BF862 I like......
MOSFET-trioda Mju folover verzija
have to try it
ehh, btw, could it be a single ended to balanced 'converter' ?
sorry if its OT
Old 9th November 2012, 12:02 PM   #25
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
nope
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 9th November 2012, 12:10 PM   #26
R.I.P.
Originally Posted by GentryBa View Post
hi everybody!
@juma:
G,
are you having a hizzy fit?
Why start again when all you are missing is a couple of jFETs?
regards Andrew T.
Old 9th November 2012, 12:38 PM   #27
juma's Avatar
Originally Posted by tinitus View Post
...could it be a single ended to balanced 'converter' ?...
SE-to-Balanced converter must include some sort of differential amplifier - a building block with inherent feedback (or degenerative) mechanism between elements that can produce signals which are opposite in phase...
Old 9th November 2012, 01:50 PM   #28
GentryBa's Avatar
@andrew:
what does "hizzy fit" mean?
Now I bought some BL-graded matched ones from toshiba.
hope this will solve my problem.
best regards,
matthias
Old 23rd December 2012, 03:08 PM   #29
GentryBa's Avatar
hi everbody!
my BL-graded fets from china aren't arrived yet. it's taking 6 weeks now.
maybe they're hanging in the customs duty?
is there any possibility to use a pair of matched GR-graded types?
which changes would be necessary then?
thank you!
best regards,
matthias
Old 21st January 2013, 08:29 PM   #30
GentryBa's Avatar
hi everybody!
my FETs arrived and Juma gave me all the needful tips to fire up my preamp.
now it was time to build the micro controlled things in it.
I didn't want to have any current through the relais-coils, so I bought some latching types with a single coil.
The latching relais are controlled by normal relais and a atmega 16.
I have 5 inputs and 2 outputs, you can rename them like you want to.
The 2x16 LCD is showing in/output status and some other things.
Selection is done by a alps encoder, if you turn the encoder, then choosing between in/ouput is possible.
Pressing the button of the encoder switches to the next menu.
When I switch to another in/output, then the normal relais get some power (for about 100ms), to switch the latching ones.
After that everything is "dead", only the audio-signal is floating through the wires...
I made a short video, sorry for the music, but the original-audio was much much harder to accept.
https://www.youtube.com/watch?v=Cb7x2WHxk-A
best regards,
Matthias
Juma's Preamp for F5 -new built-Hide this!Advertise here!
Preamp ideas for F5 ejfud Pass Labs 474 8th November 2016 03:18 AM
Firtwatt F5 built - where to buy? CENTRAL Pass Labs 30 27th January 2012 06:08 AM
Preamp in F5 manual Beftus Pass Labs 2 20th November 2009 07:10 PM
wanted built aleph x or f5/f3 boards slr 5000 Swap Meet 2 12th March 2009 08:41 AM
i want to built new preamp maxpou Solid State 8 1st January 2008 08:11 AM
