Old 20th October 2003, 07:57 PM   #1
Default IRFP240 matching
I know matching has been covered quite a few times here but here goes:
In a monoblock aleph two there are a total of 12 IRFP240, six per side. When matching do all 12 have to match or just 2 sets of 6?
Sorry if this has been covered already.
Thanks Mike
Old 20th October 2003, 08:29 PM   #2
Freddie is offline Freddie  Sweden
You just have to match two sets of six.
/Freddie
Old 20th October 2003, 08:31 PM   #3
Audiofanatic's Avatar
Default Matching!
I ones read, on this forum, that you have to match the lower and upper Fet's separatly; not the whole power section.
In other words, 2 X 6 is IMO the way to go!
To be shure, ask Mr Pass. He will give you the answer to your Q.
Audiofanatic
Be nice to animals.
Old 20th October 2003, 08:48 PM   #4
A recent article by Mr. Pass titled, "Practical Mosfet Testing for Audio" is a must read. It's in PDF format at the www.passdiy.com site.
Dan
Old 20th October 2003, 09:02 PM   #5
Only devices that actually work in pararell have to be matched.But I always wondered if devices that work at the same place in each channels should be matched to each other or not ,and how does it apply to gain of circuit and stereo balance.
Bartek
Just to sure ,I always match both channels ,so for Aleph 2 I would go for two banks of 12 devices.
Old 21st October 2003, 01:23 AM   #6
The one and only
Nelson Pass's Avatar
Interesting that you should mention it. with an "X" type amp
I prefer to match all of the negative side output transistors, and
with a slightly lessor priority all the positive side output devices
(this in the case of the XA).
Since the two opposite "channels" of the balance output cancel
distortions in common, you get a little more of that cancellation
that a diff pair input enjoys.
I don't regard this as a big item, though because once Vbe
matching has occured in a parallel bank, they statistically show a
lot of AC performance matching, particularly if they are from the
same lot code.
It still distorts, but a little less.
Old 21st October 2003, 01:28 AM   #7
Brian Donaldson's Avatar
That's a gain I didn't think of before. The more parallel devices you have, the more likely their distortions can cancel and the more each ones individual distortion is watered down.
Old 28th October 2003, 02:51 PM   #8
Magura is offline Magura  Denmark
Magura's Avatar
How close should the mosfets be matched?? There must be some sort of tolerance. Are some mosfets more sensitive to "out of match" than others?
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 29th October 2003, 12:41 AM   #9
Magura, if you look on the pass diy site there is an article on matching fets and it covers the tolerance and setup very well.
mike
WTB: irfp240 axp31 Swap Meet 0 29th November 2005 07:57 AM
Matching IRFP240... viktor1986 Solid State 7 25th November 2005 01:39 PM
Irfp240 nbcd Solid State 4 30th April 2003 07:48 PM
help matching irfp240 and irf9610 MikeZ Pass Labs 5 19th January 2003 11:19 PM
Matching IRFP240 for Alpeh2 Cephas Pass Labs 4 23rd April 2002 07:08 PM
Page generated in 0.10240 seconds (77.96% PHP - 22.04% MySQL) with 10 queries
