Old 20th October 2003, 07:27 PM   #1
Default Aleph 1.2 overbiasing
A great big thanks to my friends in Tejas and especially Nelson Pass and this forum for all work you put into this hobby. Because of my hard at work machinist friends my amps are pretty close to the point that I can start stuffing parts.
We (they) have built 3 pairs of Aleph 1.2 monoblocks that are identical to the original except we chose to build a subenclosure below the amp to house the transformer.
Ive got a couple of questions that I hope someone can answer.....
On the original Aleph 1.2 are there 6 mosfets(3 per verticle bar) mounted per side of amp?? Im assuming so, Im just not sure how the lack of heatsink fins on the I/O panel will affect the heat disapation. Any comments???
If I build a Aleph 1.2 amp with the same original heat sinks, how much could I safely over bias each monobloc. Im just not sure how much I can push it safely.
If I build the Aleph 2 with the original Aleph 1.2 heatsinks how much can I safely over bias it??/
I guess Im wondering If I can get rid of r19 without problems.
Can anyone recommend a correct rocker switch that would fit the original Aleph 1.2 amp??
Thanks!!!!!!
Tom
In The Days Before Rock 'n ' Roll
Old 20th October 2003, 09:00 PM   #2
The one and only
Nelson Pass's Avatar
Go for it. When it starts getting scary, back off or get
a fan.
Old 21st October 2003, 12:24 AM   #3
jam is offline jam  United States
jam's Avatar
Tom,
Some pictures of your amps might be nice.
Jam
Old 21st October 2003, 07:26 AM   #4
Send a message via AIM to jewilson
There are 6 Aleph 1.2 in varrious stages of completion. The heat sink area is the same on all amp, however the lower chassis is different depending to the transformer being used.
Jim W.
Old 21st October 2003, 07:30 AM   #5
Default More Aleph 1.2's
Jim W.
Old 21st October 2003, 07:31 AM   #6
Default Some More Aleph 1.2's
Jim W.
Old 21st October 2003, 07:44 AM   #7
Default Inside Amp
Inside view of chassis
Jim W.
Old 21st October 2003, 07:47 AM   #8
Default Amp Top
AMP top Plate
File Type: jpg top of amps with resessed scoket heads.jpg (41.9 KB, 356 views)
Jim W.
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 13 27th April 2012 02:13 AM
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 17 9th January 2012 02:10 PM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Page generated in 0.09363 seconds (80.40% PHP - 19.60% MySQL) with 11 queries
