Aleph-X humming\buzzing
Old 12th August 2012, 10:40 AM   #11
juma is offline juma  Germany
juma's Avatar
You still have a bus between the rectifier and the first ElKo.
Old 12th August 2012, 10:43 AM   #12
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
like this
in some cases you'll also need bridge directly between Audio gnd left and Audio gnd right , made of thick wire , laid out in shortest path
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 12th August 2012, 12:55 PM   #13
I think that hum is better suppressed if the first capacitor pair have their "ground" connection tied together before the common wire is brought to the output star.
I have not built a 3stage rCRCRC PSU, so I am not sure where the second pair of capacitors should be ground connected.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 12th August 2012, 01:28 PM   #14
Zen Mod's Avatar
nope
Old 14th August 2012, 07:56 PM   #15
jeekee is offline jeekee
Guys, thanks for all the input. I've managed to rewire the bung and the hum improved nicely. It's still there but it's almost not audible anymore. Best guess is some ripple getting through to the output.
Perhaps changing the R's for L's might reduce ripple enough. On the other hand perhaps it's worth the effort to rewire the xformer to output 24V, this will give me room to reduce ripple rigorously and perhaps use an input choke to dampen input current swings. Might also benefit the xformer hum... when aiming for a 15V rail the only problem is the current rating for the choke. If I remember correctly the RMS current would be around 10A but the peak current at about 16A. Most if not all chokes will go to about 10A, so I'm not sure whether the 16A peak will be problem... Any ideas?
Thanks again for all the GOOD help and fast answers!
Old 14th August 2012, 08:57 PM   #16
Zen Mod's Avatar
are you having hum with inputs grounded ?
Old 15th August 2012, 06:45 PM   #17
Zen Mod, good point. No hum with inputs grounded... so guess ripple isn't much of a problem. Any options left untouched to further reduce the last bit of hum?
Old 15th August 2012, 06:58 PM   #18
Zen Mod's Avatar
I can bet that amp will be silent in case of using balanced inputs
try that fat bridge wire between two gnds as I wrote in post #12
it's role is solely to kill any possible potential difference between two (channel) star gnds
Aleph-X humming\buzzingHide this!Advertise here!
Humming/Buzzing in Aura va-100 ii wonderif Solid State 5 18th February 2012 12:21 AM
One channel softer than the other, humming and buzzing Lloyd84 Tubes / Valves 3 24th September 2007 05:45 AM
Forte 1a buzzing/humming fixed? needtubes Pass Labs 3 5th August 2007 04:02 PM
A quick question about humming / buzzing markiemrboo Chip Amps 40 4th December 2006 07:41 PM
Copyright ©1999-2017 diyAudio
