Old 20th October 2003, 03:22 PM   #1
Question SOZ mod, Regulated supply VS 2 simple CC pullups.
In an attempt to further filter the power supply from the SOZ amp, what's better, regulating the power supply, or, simple BJT based constant current pull-ups?
What type of performance difference should I expect in each case?
_______
Brian
Old 20th October 2003, 03:48 PM   #2
The one and only
Nelson Pass's Avatar
Using CCS's on the positive rail will require some offset
stabilization not included in the original circuit, but is
otherwise do-able, and will result in a more efficient circuit
with even less damping factor.
ZV6 will be addressing this, so watch for it.
Regulating the supplies works well too.
Old 20th October 2003, 04:07 PM   #3
Originally posted by Nelson Pass
more efficient circuit with even less damping factor.
When you say less damping factor, you mean that the amp will have a higher damping factor value?
I forgot, the higher the damping factor, the better the amp's capability to stop the woofer, right?
_______
Brian
Old 20th October 2003, 04:49 PM   #4
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
an updated SOZ cool!!!
i built a regulated supply for my SOZ, from the Zen variations Part 3
article, and it worked quite well. So you should try that out while
waiting for Zen V6. For some reason though, i'm back to using a
Pi filter for my X-SOZ attempt (a la Henrik's schematic).
With all the presents from Mr. Pass lately, i think he figured out a way to
get UPS to deliver some extra hours for his days
Idea(s) for simple HV regulated psu rotation Tubes / Valves 6 21st February 2009 08:14 PM
3 Pin regulated supply VS zener based supply KevinLee Solid State 3 15th September 2008 02:40 PM
Regulated DC PSU - Plain and simple please? GlidingDutchman Solid State 156 26th June 2008 12:20 PM
regulated supply +- 28V -20A sss Power Supplies 8 14th June 2005 07:30 AM
regulated 5V DC supply Tomatito Tubes / Valves 50 4th February 2003 08:33 PM
Page generated in 0.08929 seconds (71.89% PHP - 28.11% MySQL) with 10 queries
