diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   F5 heat sink, rhetorical question, (http://www.diyaudio.com/forums/pass-labs/217369-f5-heat-sink-rhetorical-question.html)
john s 5th August 2012 10:31 AM
I'm moving to Mexico in about 4 months and have all the components and boards from the shop for Nelsons F5
i recently took apart a Cambridge 5.1 surround sound receiver and have the
have a heat sink with fan attached, small neat and compact,
this was cooling six B817 E4E1's six, D1047 E 4F1 and six D946BR, although i haven't a clue what they are but hope someone can identify them from the numbers,
Question would the 4 fets in an F5 generate more heat than this lot, ?
thanks for any thoughts or input,
John S
Zen Mod 5th August 2012 11:06 AM
pics please
john s 5th August 2012 11:22 AM
Hi Zen,
Thanks i've taken some with my mobile and will try to post as soon as i've saved them and figured out how to post them ???,
John S
powerflux 5th August 2012 11:35 AM
keep the fan and you'll be safe. if you don't it certainly won't be enough
Zen Mod 5th August 2012 11:37 AM
Originally Posted by john s (http://www.diyaudio.com/forums/pass-labs/217369-f5-heat-sink-rhetorical-question-post3115487.html#post3115487)
Hi Zen,
John S
reply-scroll down - manage attachments-browse-mark-open-upload-close this window-submit reply
keep them up to 1200pix , jpg or gif
john s 5th August 2012 11:45 AM
Originally Posted by powerflux (http://www.diyaudio.com/forums/pass-labs/217369-f5-heat-sink-rhetorical-question-post3115493.html#post3115493)
Thanks yes i had realised that i know its not enough on its own i will also put in a sensor to switch off the amp if it gets to hot,
John S
john s 5th August 2012 11:48 AM
Originally Posted by Zen Mod (http://www.diyaudio.com/forums/pass-labs/217369-f5-heat-sink-rhetorical-question-post3115495.html#post3115495)
thanks Zen i still have to find them to post, to many photos of good looking women in the folder to scroll through, !!!!!
John S
john s 5th August 2012 11:57 AM
6 Attachment(s)
size is 9 inch long by 3 x 3
John S
Zen Mod 5th August 2012 12:00 PM
1 Attachment(s)
it will perfectly cool F5 , presumably with lazy spinning vent ( 7-8Vdc)
make tunnel around fins - you can use any sort of plastic foil for that ...... maybe piece of Roentgen (I scavenged full pack of these from buddy working in local lab) , so it will be most effective
attached fan control by Papa
it will start fan with full throttle and slow it down immediately
PSU voltage - simplest - just put 7812 reg in front , in case of feeding it from main amp PSU
john s 5th August 2012 12:07 PM
Thanks Zen
i'll tunnel it as you suggest yes i had intended fitting a circuit to power the fan
i think its 6 volts but will fit a pot to vary the speed,
regards all
John S
Resources saved on this page: MySQL 18.75%
