Old 31st July 2012, 01:56 AM   #1
elecres is offline elecres  United States
elecres's Avatar
Default Aleph 3 / power supply
Newbie building a Aleph 3 . pics. attached. looking for info on the build and want to use 20k 100v caps in pic and looking for info on PS LAYOUT ,also would like to point to point [hardwire] the ps components. tnx in advance hopefully the build turns out ok!!
As in life,brilliant moments are worth the price of admission !!
Old 31st July 2012, 04:06 AM   #2
What kind of information are you looking for? (I built an Aleph 3 that I absolutely love).
Look at the Burning amp docs on passdiy for PS schematics that you can use.
I have 2 56k uf(50v) caps per rail and a Jantzen 2.2mH 15 AWG Air Core Inductor in between instead of the resistors. Chokes instead of resistors made a noticeable difference in the sound.
The transformer is 18+18(400VA) from antek.
-uv-
Old 1st August 2012, 12:37 AM   #3
elecres's Avatar
THAT KIND OF INFO, TNX ! ALSO ORDERED 4.7 UF JANZEN CAP FOR POWER SUPPLY . FOUND ALEPH3 POWER SUPPLY SCHEMATIC TODAY : ] I ALSO HAVE ANTEK 20+20 THINK 600VA
Old 1st August 2012, 12:39 AM   #4
elecres's Avatar
NO IT IS A 400VA ALSO
Old 2nd August 2012, 02:08 PM   #5
Think you are right to keep the electrolytics as far away from the heat sinks as possible.
You could cut a square piece of FR-4 or aluminum - drill 4 holes near the corners
and then connect the 4 terminals of the electrolytics to it.
This would be your ground reference node.
If you use FR-4, it will need to be sprayed with a mask to stop oxidizing.
You may want to consider insulating the tops of those electrolytics.
Will your case have ventilation from the bottom and the top ?
I see you are using a soft start - good.
I'm wondering - How important is it to keep the diodes bridges away from the amp circuitry ?
Old 2nd August 2012, 02:15 PM   #6
You want to keep the loops formed by the transformer - diodes - first large cap tight/short since current flow there is large and transient as it only flows when the voltage across the transformer secondary is higher than what is stored across the capacitance (plus the diode drop)
Old 2nd August 2012, 04:57 PM   #7
Thanks for the advise - I'll try to keep the secondary - diode - first cap loops short.
Old 3rd August 2012, 01:44 AM   #8
elecres's Avatar
yes , I planned on using copper squares for caps and yes will have ventilation top and bottom!Hopefully it all works out well , if it does I want to add volume pot and make it a intergrated.
Aleph 2 power supply MikeZ Pass Labs 50 9th November 2012 01:40 PM
Aleph X power supply Mach_Y Pass Labs 42 29th March 2004 08:43 PM
Aleph-4 Power Supply needs help ruangrit Pass Labs 1 25th January 2004 05:38 AM
Aleph 5 Power Supply martinschki Pass Labs 66 25th January 2003 06:34 AM
Aleph 5 power supply. Tony D. Pass Labs 11 30th September 2002 09:08 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 18.18%)
Copyright ©1999-2013 diyAudio
