Aleph 60 building thread
Old 11th October 2012, 02:04 PM   #71
PKI is offline PKI  United States
PKI's Avatar
Originally Posted by AudioSan View Post
it is R18 on the PCB that is 392ohm. R17 is 221ohm.
Nope :-) I am looking at the spreadsheet now: R17, R18 are 392, but with the comment: initial value, could be optimized for expected power/load conditions for R17.
Old 11th October 2012, 03:24 PM   #72
AudioSan is offline AudioSan  Norway
on the schematic i got for A30, it is only R18 that is marked 392ohm. but i see R17 is marked 392ohm on the spreadsheet for A30. however. it is marked 221ohm on the A60 schematic.
so if it is A60 you are building. stick with 221ohm.
Old 11th October 2012, 03:29 PM   #73
PKI's Avatar
Thanks, I will go with 221 first and then will see!
There is only one thing between me and assembled A60 bock — wires. Bought 12awg teflon wires, but the strands are covered with some "silver" metal that does not soldering well :-(.
Old 11th October 2012, 03:46 PM   #74
another reason to stick with good old trusty copper
i just take a extention cord wire with 3x1.5mm2 and strip it
but for the A60 you can go for something a little more beefy.
Old 12th October 2012, 04:21 AM   #75
PKI's Avatar
Guys, what to do with R19(R13 pcb). It's 5622?! I have a multiturn trimmer for 10k, or find something else?
Old 22nd October 2012, 03:39 AM   #76
PKI's Avatar
okei. from the front end board to the first output board:
+c - +c. +v - +v. +g - +g. +s - +s. and then, from one output to another output:
+c -+c. +v - +v. +g - +g. and you are done same for the negative side
I have 12awg, 14awg and kimber 19awg wires. Which are better suit for +s, +g? I am thinking of 12awg for +c, +v and smaller diameter for other two.
Old 22nd October 2012, 09:39 AM   #77
Danger Mouse is offline Danger Mouse  Germany
Danger Mouse's Avatar
I think its 56,2k
Seen this kind of number in x2 manual.
means 562 and 2x 00 is 56200ohm
Last digit says how much 0 you must add
could also be that i`m wrong
Old 22nd October 2012, 12:48 PM   #78
PKI's Avatar
Originally Posted by Danger Mouse View Post
I think its 56,2k
Is this true?! :-( I was thinking that this is just 5.62k, no?
Old 22nd October 2012, 11:37 PM   #79
look there
Pass Labs X2 REV1 Relays?
I think Pass forget to translate R19 and R21.
When I will do my Aleph60 I will try R21 1,5k and R19 56,2k
I`ve looked at the serive manual from the Aleph30 there R19 is 47,5k
why should it be so much different in the 60?
I will try when time is come hopefully my Amp dosn`t burn down
greets Alex
Old 22nd October 2012, 11:43 PM   #80
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
5622 means 562 x 10^2 = 562 x 100 = 56K2
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Aleph 60 building threadHide this!Advertise here!
60 day 'Cool Down' (study?) period before newbies can post a new thread? Andersonix Forum Problems 24 16th May 2012 11:46 AM
My Aleph 60 Nat Riscica Pass Labs 39 21st January 2010 11:59 AM
Resistor R! for Aleph 60 redwine1118 Pass Labs 3 24th February 2005 12:43 AM
Aleph 60 instead of Aleph 2(newbie) mats73 Pass Labs 12 22nd March 2003 09:33 AM
aleph 60 janey Pass Labs 3 18th December 2001 09:02 PM
