Aleph 60 building thread
Old 3rd October 2012, 10:17 PM   #41
6L6 is offline 6L6  United States
6L6's Avatar
6 per channel? I.E., 3 current sources and 3 outputs?
Or 6 outputs and 6 current sources per channel? (You will need a fan.) (Or 2)
If you want to use just the ones that will mount on that board, because you have such tall heatsinks, I wouldn't break the boards and just use them as one piece.
Old 3rd October 2012, 11:32 PM   #42
PKI is offline PKI  United States
PKI's Avatar
I am confused! :-( aleph 60, original layout has 12 outputs as I see, right? I was told earlier that I will be ok with two monoblocks(one on the photo above) for the amp. No, I got everything wrong? :-(. I can assume it as I am not an expert :-)
Old 4th October 2012, 12:01 AM   #43
AudioSan is offline AudioSan  Norway
aleph 60 have 6 outputs and 6 current sources pr ch
you can do it with 4 of each too
Old 4th October 2012, 12:07 AM   #44
6L6's Avatar
I had to look at the Aleph60 schematic, and yes, it has 6 CCS fets and 6 outputs per channel.
It will heat your house. Neat!
You will need another set of the BrianGT boards in order to use them for their daughterboards. My understanding is that you can daisy-chain them in series to get as many outputs as you need.
Old 4th October 2012, 12:20 AM   #45
6L6. yes you can but he don't need to order 2 sets. brian can also sell the boards with dobble set of output boards
Old 4th October 2012, 12:21 AM   #46
i suggest to build it as monoblocks. they will give you a lot of heat. about 180-200W pr ch.
Old 4th October 2012, 02:29 AM   #47
PKI's Avatar
So, I guess we have a bit of misunderstanding here. I will try to clarify:
The chassis I posted above is for one channel -- monoblock. It has two .2 c/w heatsinks. I am assembling one first and then copy it.
Here is the photos of what I have now:
Ready to be stuffed.
So my question is still: how to hook up these daughter boards in parallel in the best way?
Old 4th October 2012, 03:06 AM   #48
aha. this seams just fine the two paralell boards are hooked up with 3 cables. (at the end of the board. and 4 cables from one board to the front end board this is marked on the front end board
EDIT: not the end of the boards. i'll find my boards and get back to you just a min.
Old 4th October 2012, 03:10 AM   #49
6L6's Avatar
It looks like the daughterboards have 2 sets of connections, so you can attach one to the main board, and then the daughterboards together. Do that for each side (CCS and amp)
Old 4th October 2012, 03:15 AM   #50
okei. from the front end board to the first output board:
+c - +c. +v - +v. +g - +g. +s - +s. and then, from one output to another output:
+c -+c. +v - +v. +g - +g. and you are done same for the negative side
Aleph 60 building threadHide this!Advertise here!
60 day 'Cool Down' (study?) period before newbies can post a new thread? Andersonix Forum Problems 24 16th May 2012 11:46 AM
My Aleph 60 Nat Riscica Pass Labs 39 21st January 2010 11:59 AM
Resistor R! for Aleph 60 redwine1118 Pass Labs 3 24th February 2005 12:43 AM
Aleph 60 instead of Aleph 2(newbie) mats73 Pass Labs 12 22nd March 2003 09:33 AM
aleph 60 janey Pass Labs 3 18th December 2001 09:02 PM
