#11 |
Is it ok that on the boards there are only 4 1ohm 3w resistors and 6 of them on the schematic? And why there are two resistors in parallel on output boards(source)?
#12 | |
As for the number of 1R resistors I would go for the original number and take 6. Of cause doing this you must also use all the other original values. You can solder the two more resistors a bit higher simply over the four, they are all parallel......
and the First W tt is......a really First Class P |
#13 |
#14 |
R8 and R14+pot do the same .....changes of the resistor value give more or less voltage at the gate uF the Output IRFs. Adjusting them bring the value of the offset to Zero.
But warming up may change the value again.....or when your input Mosfets are not perfectly matched... And R1 does the trick to keep these changes nevertheless very small! So R1 is one of the perfect ideas of Nelson to minimize the offset changes! R8 or R14 only bring the offset in the beginning or after an hour near zero but do not avoid the small changes over the time that can go up to 100mV. R1 makes a kind of automatic minimizing the offset changes all over the time......
#15 |
Thanks, got it (sort of :-). So, R1 should be variable, yes?
#16 |
R1 is experimental, you start with the recommended value of some megohm and you observe the offset.....for instance when it is beginning with around 10-20mA and stays in this ballpark after some time you have won...
if the value is still too great you start to change....... make it bigger and smaller and see the effects direction coming to the goal of 10-20mV at the output. You stay with this value. Works really fine and if the input Mosfets are closely matched you even do not need the pot I mentioned or any change of the other mentioned resistors..... good luck.... I do the same at the moment, I use this Mosfet input stage to drive two Semisouth and I prefer the sound at the moment over the 2SJ109 input stage..... not so detailled, but simply more sound.......! I like this kind of mosfet bloom!
and the First W tt is......a really First Class PLast edited by generg; 1st August 2012 at 08:00 AM. |
#17 |
I am about to order at mouser; thermal paste:
I have some from CPU/cooler combo, is it good, or it is better to order this:120-2 Wakefield | Mouser (or some other from mouser)? |
#18 |
that one from Mouser is good enough
![]() I'm not using those for CPU - some are/were electrically conductive better safe than sorry
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#19 |
I just realized that I bought wire-wound vishay dale 1ohm 3w resistors, not metal film... How bad is it ?
#20 |
that works fine.
aleph P1.7 pre. F5 power amp. CDpro2(need DAC). Vivaldi8 speakers |
| 60 day 'Cool Down' (study?) period before newbies can post a new thread? | Andersonix | Forum Problems | 24 | 16th May 2012 11:46 AM |
| My Aleph 60 | Nat Riscica | Pass Labs | 39 | 21st January 2010 11:59 AM |
| Resistor R! for Aleph 60 | redwine1118 | Pass Labs | 3 | 24th February 2005 12:43 AM |
| Aleph 60 instead of Aleph 2(newbie) | mats73 | Pass Labs | 12 | 22nd March 2003 09:33 AM |
| aleph 60 | janey | Pass Labs | 3 | 18th December 2001 09:02 PM |
