#101 |
#102 |
which trick ?
replace R11 (looking at original A60 sch, posted in #1) with series connection of 150R fixed resistor and 100R multiturn trimpot ; vary it and you'll get 0 on output , at temp. equilibrium both inputs grounded during setting procedure
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#103 |
Oh, thanks! I thought it is all about R8*( comment on 8Mohm there).
#104 |
Ok, guys, I have a bigger problem -- There is only 4V between -V and -G on the board (and negative daughter boards, respectively). Everything is ok(~28v) on the positive side. PSU gives 33V to the board.
Any ideas? Could I damage input transistors while soldering? I really need your help as it is my first ss DIY serious amp! |
#105 |
well at 10:45 last night you were power up the supply, and now I see a almost done amp...You had to be hard at it to get to this point, now take a break and watch a football game. Think about it and come back. Then start with all wire connections.
Meanwhile the thread will get some replies on where to look, also Steve
If a inch of duct tape will fix it, 3 feet should fix it for life!!!! |
#106 |
Thanks Steve :-). I'll try a little bit more: i have 28.5 V between -G and ground. On the positive part its only 4V...hm...
I tested input transistors with multimeter I get some readings if i touch: neg. on source then switch pos. from gate to source. |
#107 |
Here is my own example of finding problems after a night of "putting it all together" It was simple, ground wire wrong place, seems kinda funny now. It worked on the bench, and then.....
The Mini-A Now it runs smooth. We have all had those days. ![]() Steve Do you have 9V across Z5?
If a inch of duct tape will fix it, 3 feet should fix it for life!!!! Last edited by HIPCHECK; 4th November 2012 at 10:03 PM. |
#108 |
Funny, my plays music but very quiet :-)
#109 |
Hm, or there should be 4.8V between -G and -V as it is exactly voltage drop on R14(18).
The thing is, it is extremely quiet even with my pioneer hpm which are 95db sensitive... Another, i run it for an hour(played led zeppelin 2,4) and it is not even close to the temperature i expected, it is like 40-45C max. Voltage across source resistors 0,34V(should be .37V according to A60 schem.) |
#110 |
Balanced or single ended input? What source? etc
| 60 day 'Cool Down' (study?) period before newbies can post a new thread? | Andersonix | Forum Problems | 24 | 16th May 2012 11:46 AM |
| My Aleph 60 | Nat Riscica | Pass Labs | 39 | 21st January 2010 11:59 AM |
| Resistor R! for Aleph 60 | redwine1118 | Pass Labs | 3 | 24th February 2005 12:43 AM |
| Aleph 60 instead of Aleph 2(newbie) | mats73 | Pass Labs | 12 | 22nd March 2003 09:33 AM |
| aleph 60 | janey | Pass Labs | 3 | 18th December 2001 09:02 PM |
