Question about Pass a40 and speaker loads
Old 21st April 2001, 05:17 PM   #11
Eric is offline Eric  United States
Eric's Avatar
Unhappy Now I'm getting the picture!
So that's what Nelson meant when the said the design cannot easily be modified for higher power...
It looks like a good compromise might be to design for 40w into 4 ohms as well. Thanks for all of your help! I do appreciate it!
Eric
Old 23rd April 2001, 01:16 PM   #12
Eric's Avatar
Question Some additional thoughts...
Thanks for all of your help and patience with me! Is this why this type of design referred to as a "constant current" ? It seems that the bias current does not change under varying loads, so you're stuck with making the best of the available current, no matter what the speaker load is.
Old 23rd April 2001, 03:02 PM   #13
Geoff is offline Geoff  United Kingdom
Eric
The A40 is not a 'constant current' amp as it has a push-pull output that will continue to operate outside the Class-A limits. The supply/load current will vary from zero to twice the quiescent current in Class-A mode and even higher when driven into Class-AB. The power availability is limited by the supply rail voltage and by the capabilities of the power supply. Taking the previous figures of 30V rails and an Iq of 2.25A, the limits will be: 40W into 8ohm (Class-A) and 40W into 4ohm (Class-A) or about 80W into 4ohm (Class-AB). Even higher power would be available into a 2ohm load, the limit being set by the power supply and by the output transistor capability/protection circuit.
A 'constant current' amp has a single ended output stage which will provide no more current into low impedance loads than that catered for in the design (i.e. Iq or sometimes up to twice the Iq for special designs). Single ended amps are limited to Class-A operation and cannot move into Class-AB if presented with a low impedance load (unlike most push-pull output stages).
Geoff
Old 23rd April 2001, 03:21 PM   #14
Eric's Avatar
Thumbs up Thanks Again
Thanks for the explanations, Geoff! My mentality started off with "just follow the instructions, and you'll have a nice amp". I'm quickly moving into the "gotta know more!" phase.
I've read Randy Sloan's book, but there are many topics here that he does not address. Most of his designs seem to lean toward Class-B stuff.
Eric
[Edited by Eric on 04-24-2001 at 08:13 AM]
Old 24th April 2001, 10:30 AM   #15
Eric
If you want more information on Class-A working, have a look at the Class-A Amplifier article (amongst others) at the ESP Audio Pages ( http://www.sound.au.com ). I assume you have read the article on Class-A amps at the Passlabs site since you have been considering the A40.
Geoff
Question about Pass a40 and speaker loadsHide this!Advertise here!
Speccing power transformer for several speaker loads privateer Chip Amps 6 22nd June 2005 01:38 PM
Any point in putting dummy loads on unused speaker outputs on headunit? eRiCdWoNg Car Audio 2 6th May 2004 08:12 AM
? HT speaker loads and amp power 2Bit Multi-Way 2 8th January 2004 10:49 PM
Best amp choice for driving NASTY speaker loads stokessd Pass Labs 8 25th March 2003 11:32 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
