#51 |
well. say the F5 CAN push 100W (it is very possible)
i cant see any difference from pushing the aleph4 in the same room with the same speakers. exept that the F5 will deliver more power on lowZ's. so the F5 will do it better
aleph P1.7 pre. F5 power amp. CDpro2(need DAC). Vivaldi8 speakers |
#52 |
If you say so. I sold my F5 on E-Bay.
#53 |
The one and only
#54 | |
Thanks for this info - its very useful. The 683's drop down to Z = |3.0| - I don't think an F5 is designed for this. My preference with B&W's is tubes in the preamp and MOSFET's in the power amp. - and solid core copper speaker cables. - something to look into is solid core OCC copper with teflon insulation. there are only 3 companies licensed to make OCC copper wire and its sold under quite a few brand names. With my N804's - I'm thinking of bi amping with a small class A MOSFET amp going to the mid/tweeter and a Bi polar push - pull amp going to the bass. B&W has really improved the crossovers with their Diamond series. In my 603 s2's and N804's they used Bennic resistors and MKP caps. What were they thinking ? I rebuilt the tweeter crossover section in my 603's and it was a huge improvement. I suspect an Aleph 4 can drive the 802D's because of a very low Zout and they can deliver lots of current. . . Last edited by Uunderhill; 29th July 2012 at 05:08 PM. |
#55 | |
Have you read the F5 article? HAve you read the F5T article? K&D may not like the f5, but he is simply wrong about its abilities. If the standard F5 is not suited for your speakers, the F5T V2 or V3 will EASILY drive your speakers. You may not like it, but it isnt because it is having trouble doing the job. Be careful that you check what others say. BTW, he is comparing a 25W F5 to a 100W A4.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! Last edited by buzzforb; 29th July 2012 at 05:11 PM. |
#56 | |
just like us, its fun to him. it just so happens hes one of the lucky ones who can pay the bills off his fun.
I'm not crazy, my mother had me tested |
#57 | |
I think what makes a speaker an easy load is the magnitude of the impedance curve and its phase angles. Speakers with mostly a real impedance where Z >= |4 | ohms are a reasonable load to drive. Speakers that have large phase angles - where there is a large rate of change in the phase angle combined with a low Z magnitude - can be hell for an amp. IMO an amp with a very low Zout - combined with a huge power supply - is needed for speakers like these. I don't know which 3 way Scan Speak speakers you have, but from what I've seen from Seas and Scan Speak designs, the real and imaginary components of the impedance, provide a reasonable load. Have is Troels Gravesen's builds of Scan Speak's - bless this person. ScanSpeak Projects . . . Last edited by Uunderhill; 29th July 2012 at 05:45 PM. |
#58 |
Unnderhill. my scan-speaks are my own design. based on the good old classic series.
2x8" bottom, 7"mid and 9500 tweeter. the 8" drivers are custom 12ohm. not 8ohm as standar.
#59 | |
Mr. Pass, Juma and Zen Mod have been very kind to help me with the mods. The F5 has some great advantages - its dead quiet - there is no thump with switch on and off - Beethoven piano Trios and Mozart piano concerti sound great with it. - sonically I really like this amp From a Zout point of view, the F5 has a parallel common source output stage. So I think its really intended for speakers that are reasonable load. It drives my 10" 2528 DC Tannoys beautifully. K&D has B&W's where the Z =< |3.0| , with difficult phase angles - these speakers put huge demands on an amp. The aleph 4 has a follower output - so I suspect its Zout is very low. Plus the power supply could run a fork lift. . Last edited by Uunderhill; 29th July 2012 at 06:17 PM. |
#60 |
If you compared an F5T rated at 100W like the F5T v3, you would find the differences, other than sound, to be minimal. The two amps, equally rated in power, will aoun different due to topology, not the ability to drive the speakers effectively.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
| DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM | stevep314 | Analog Line Level | 0 | 10th August 2010 09:15 PM |
| DIY Low Pass and Mid/High Pass (Bass Blocking) Filters | runslikealpaca | Everything Else | 1 | 19th June 2009 10:59 PM |
| OEM Digital Crossover now Available to Diy Market | Daytona50 | Swap Meet | 16 | 16th January 2009 11:45 PM |
| Pass Diy High Low Pass Please | macka | Pass Labs | 127 | 2nd March 2004 11:00 PM |
