To DIY, or OEM PASS?
Old 28th July 2012, 02:58 PM   #11
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Turn on surge may well be more of a problem with 110V supply.
Old 28th July 2012, 02:58 PM   #12
AudioSan is offline AudioSan  Norway
well. then your mains have to handle above 6000W power surge on start up.
Old 28th July 2012, 03:04 PM   #13
tsiros is offline tsiros  Greece
tsiros's Avatar
Send a message via MSN to tsiros To DIY, or OEM PASS?
Well, Mr Elliott thinks the soft start is a good idea
Old 28th July 2012, 03:04 PM   #14
It's working and I've never had a fuse blow or my RCD on the house mains trip.
Old 28th July 2012, 03:05 PM   #15
Originally Posted by tsiros View Post
Well, Mr Elliott thinks they soft start is a good idea
As I said, try without, if you need it then use it.
Old 28th July 2012, 03:10 PM   #16
This is not meant in a nasty or derogatory manner but UK electrical installations are renowned for their safety and the correct application of physically sound principles.
In countries with lesser mains installations you may well benefit from a soft start approach.
My house has four ring mains each is rated at 32A (240V) so 7680W each.
I have no problem with tripping breakers.
Old 28th July 2012, 03:12 PM   #17
tsiros's Avatar
****, 50 euros, i'm buying
IM IN GREECE. YOU UNDERSTAND? THE FRIDGE TURNS ON AND MY SPEAKERS PUFF. THE TAXI COMES ROUND THE BLOCK AND I CAN HEAR THE CB. I AM NOT EVEN SURE MY HOUSE IS EVEN EARTHED!!!
Old 28th July 2012, 03:16 PM   #18
You might well need it. I would leave a space for it but fit it only if you need it.
At the very worst you might pop a fuse.
Old 28th July 2012, 03:31 PM   #19
32A??? well. that explains a lot.
i said 230V 16A
Old 28th July 2012, 03:32 PM   #20
tvrgeek is offline tvrgeek  United States
Sounds like more than one issue. Bad connections are what usually causes wiring to become antennas and rectify the CW. Besides checking inside your house very carefully, a very good filter can solve that. ( Bad connections have a nasty habit of burning down houses) Track down DVV. Sagging lines are another problem. The only fix I know is massive regulated supplied or external stepping transformers.
To DIY, or OEM PASS?Hide this!Advertise here!
DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM stevep314 Analog Line Level 0 10th August 2010 09:15 PM
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
OEM Digital Crossover now Available to Diy Market Daytona50 Swap Meet 16 16th January 2009 11:45 PM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
