Old 25th July 2012, 12:13 PM   #1
jeepy is offline jeepy  Switzerland
Default Back to the Citation 12
Hello,
Could the 2sa970 and 2sc2240 replace the MPSL01 and MPSL51 even if their Hfe is higher? ..>200. (I have a reasonable stock of those). Output stages will use IRF130 and power rails = +/-41V.
Thanks,
jeepy
Old 25th July 2012, 01:05 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Originally Posted by jeepy View Post
Hello,
Could the 2sa970 and 2sc2240 replace the MPSL01 and MPSL51 even if their Hfe is higher? ..>200. .....
irrelevant
look just at P , I , U of xsistors for substitution
....... Output stages will use IRF130 and power rails = +/-41V.
rails are somewhat high for those IRF's
be careful with that axe , Eugene ;
either :
- use lower rails,or
-use mosfets with higher voltage range,or
-be sure that you're not using full swing on output
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 26th July 2012, 10:57 AM   #3
Hello,
Generally speaking, with an amp made from BJT's, its the circuit that sets the gain,
not the Beta (hFE) of the BJT.
But don't use a darlington where a singe BJT should be.
If you look at the datasheets, there are typically clues - like Noise Figure or maximizing hFE
of where its best to set the bias for that particular BJT.
As Zen pointed out, also make sure Vce(max) and P are well within the BJT's limits.
In this case, I'm wondering if the higher Beta will actually improve the CMRR
of the differential pair.
Old 26th July 2012, 01:06 PM   #4
Thanks to you and Zen!
The 300mW PD may not be enough for the Vas and driver so I will use the 2N5551 instead. I will use the 2SA940 for the diff pair due to better noise figure and other specs in range.
Thanks again
Simulation - Pass MF-12 MOSFET Quasi Comp (Original) Modification for HK Citation 12 PB2 Pass Labs 30 14th March 2013 05:31 PM
Simulation - Pass MF-12 MOSFET Fully Comp Modification for HK Citation 12 PB2 Pass Labs 0 10th May 2011 03:11 AM
Citation 12 help paco161 Solid State 173 24th April 2009 12:25 PM
Citation 12 nickgreek Solid State 6 22nd September 2003 03:20 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
