F6 Amplifier
F6 Amplifier
Old 20th August 2012, 12:51 AM   #891
Antoinel is offline Antoinel  United States
F6 Amplifier
Originally Posted by buzzforb View Post
If drawn with the PSU, dont we see that both fets are passing signals through the PSU to the load, sort of like a circlotron. That is why Kasey got double the gain of what a single fet would yield
buzzforb: I hope that I put your words above in 3 simplified schematics of the attached file. Fig. 1 shows the direction of current flow [Io] through the load from the upper JFET only due to a positive signal at its gate. Fig. 2 shows the direction of current flow [Io] through the same load from the bottom JFET only due to the remaining [inverted] portion of the sine signal at its gate. Fig. 3 shows the integrated current through the load from the contribution of the upper JFET [shaded positive part of sine] and the contribution of the lower JFET [unshaded negative]. Its net value= 2Io. The net voltage across the load Zl is equal to 2Io multiplied by Zl.
Old 20th August 2012, 01:11 AM   #892
kasey197 is offline kasey197
The Dastardly Dad of Three
F6 Amplifier
Kasey197 or others,
Is bias stablity an issue with the simple R divider version?
Not for me ... but both types of fets I tried had a postive tempco (2sk1058 and SS R100s). I presume with vertical fets IRF etc youd have to add a tehrmistor to keep things well managed but never tried it (beyond frying a pair of IRFs in complementary pp)
Old 20th August 2012, 01:13 AM   #893
F6 Amplifier
Originally Posted by lhquam View Post
I think I have found a simple and very stable bias circuit for the F6.
I wired it up and made measurements. From 500Hz to 20KHz the THD behaves as one would expect. Below 500Hz, the THD increases in a highly erratic manner. See the figures below.
All tests were with 8 ohm load, 1.3A bias and 25V rails.
The frequency sweep is at 1 watt.
The power sweep is at 1kHz.
The spectrum is at 1kHz and 1 watt.
I am temporarily withholding the schematic so that I do not spoil your fun.
Well done !!
How much was the gain of the complete circuit ? Im assuming your tx is set up is 1:1 right ? Edit: Also if/when you get a chance, what was the output impedance you found ?
Last edited by kasey197; 20th August 2012 at 01:34 AM. Reason: added question re output impedance
Old 20th August 2012, 01:20 AM   #894
F6 Amplifier
ZM, lhquam and others... I am wondering what i'm missing regarding the DC through the coils issue.
I'm using this approach at the moment and tried measuring the DC current thru the coils but couldn't get anything. Was wondering if i'm oversimplifying things in my head or perhaps the current starts to appear in some cases which I haven't tested for ? Eg maybe if driving the fets >3V with SS R100s in output etc ?
Just want to make sure I understand before I order some nice input txs
Cheers all,
Old 20th August 2012, 01:29 AM   #895
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Originally Posted by Nelson Pass View Post
Operating Common-Source, they are both voltage and current amplifiers.
Antionel,
I could be totally wrong, but I was considering this if both fets are seeing the same signal.
KAsey,
What is preventing DC through the coils? Doesnt the coil see the DC bias for the fet or is your cap stopping that?
...Shape the sound , Man!
Old 20th August 2012, 01:36 AM   #896
lhquam is offline lhquam  United States
Originally Posted by kasey197 View Post
Well done !!
The closed-loop gain was slightly less than 6x, using 50 ohms and 10 ohms for the feedback divider. Tx is 1:1, both primaries in parallel. I haven't attempted to measure output impedance.
Old 20th August 2012, 01:38 AM   #897
buzzforb's Avatar
Ilquam,
What values are you using on the input jfet? I have 10Rs with 200R trimmmer across them to trim offset.
Old 20th August 2012, 01:38 AM   #898
F6 Amplifier
cool thanks!!
Old 20th August 2012, 01:42 AM   #899
Cheers all,
You shouldn't need those caps.
The main problem with this circuit is that it is sensitive to rail voltages. If the fluctuate, the bias changes. There will be only a couple of microamps through the coils due to the FET gate leakage. Otherwise there is no DC path. My R100s have Vgs=1.33V at 1.3A.
Old 20th August 2012, 01:44 AM   #900
buzzforb's Avatar
Zener is easiest way to give stable voltage. Noise may be an issue, but how important that is, I don't know.
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 05:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 09:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 08:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 09:38 AM
F6 traw Pass Labs 7 2nd November 2007 08:09 PM
