F6 Amplifier
F6 Amplifier
Old 18th August 2012, 01:43 PM   #851
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I think you will find something similar in bias setup of BA1.
...Shape the sound , Man!
Old 18th August 2012, 03:14 PM   #852
Antoinel is offline Antoinel  United States
F6 Amplifier
Also the links in Post #35.
Old 18th August 2012, 05:04 PM   #853
F6 Amplifier
Hello buzzforb. I found the official BA #1 output stage in the article by Mr. Pass entitled Burning Amp Number Three. Please find attached a hand copy of what may be your underlined suggestion. Is it? I show the bias circuit for the upper and the different one for the lower MOSFETs. I inserted the secondary windings of the transformer where I saw possible. Can you or other answer the two questions regarding points A and B of the bias circuits.
Old 18th August 2012, 05:08 PM   #854
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F6 Amplifier
You can't develop a bias voltage across the coils, so it will only work for
those cases where you can bias at Vgs=0, in which case you don't need
all that circuitry anyway.
Correction: for depletion mode devices, the bias would be 0v between
the Gate and the other end of the Source resistor.
Old 18th August 2012, 05:12 PM   #855
F6 Amplifier
Thank you Mr. Pass. The dc resistance of the transformer's secondary is ~28 Ohms [previous post]. But suppose the same bias circuits are modified so as to supply ~45 mA each [past post] and generate the needed Vgs across the transformer's secondaries. This approach may be like that of lhquam who wanted to use CCSs.
Old 18th August 2012, 05:41 PM   #856
lhquam is offline lhquam  United States
Actually the idea was proposed by tadek in this post: http://www.diyaudio.com/forums/pass-labs/216616-f6-amplifier-80.html#post3128183. I was just exploring the implications of that idea.
Old 18th August 2012, 05:47 PM   #857
F6 Amplifier
Thank you lhquam, and my apology tadek as I usually care for proper referencing.
Old 18th August 2012, 06:32 PM   #858
buzzforb's Avatar
Nelson, Mayhave something up his sleeve, but i don't see getting away without a cap. THought about it all day. Only way i know is using CS, which ZM says is bad idea to load secondary( I tend to listen to him), or putting jfet after interstage and that's adding a stage. I wonder about a level shifter, but don't know much about them. ANyhoo, I dont know much,probably less than everybody else commenting, so I would follow their advice. As for BA1 bias scheme, I was just thinking in terms of simple Zener reference, but cap is still needed.
Old 18th August 2012, 06:43 PM   #859
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
here we go again
maybe I'm rotten , knowing (at least partially) direction in which Papa is heading ......... but everything is already written
not best , not only , not sole possible way of doing things ........ but certainly most elegant and practical way of doing it
I'm probably most stubborn guy around , always trying to do things different from Pa's way of doing it ........ even if that means that my solution is always more complicated and less elegant ...... but this time - there is no sane way of doing it without cap in series with secondary
at least not with small signal xformer
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 18th August 2012, 06:59 PM   #860
Loudthud is offline Loudthud  United States
Loudthud's Avatar
Wouldn't bias currents in the secondaries cancel each other out? If there was a circuit that tweeked one of the current sources to trim offset, that would be an error that wouldn't be cancelled.
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
Copyright ©1999-2017 diyAudio
