F6 Amplifier
F6 Amplifier
Old 17th August 2012, 12:35 AM   #831
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
and then hasta la vista baby ......... to simplicity and elegance
having 2 caps is small price for elegance , especially considering that their influence is exactly opposite in character , in every moment
2 caps and few resistors , without need for bigger xformers , which eventually will be needed , considering fact of pushing twice 40++mA through tiny nickel cored bstrd
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 17th August 2012, 12:47 AM   #832
lhquam is online now lhquam  United States
Default CCS noise problem?
One aspect of constant current sources that has not been discussed is noise. The noise current of the ccs multiplied by the DC resistance of the winding will be an additional noise voltage on the FET gate. I am not sure how this might compare with other noise sources, but it is likely to be much higher than the noise injected from the circuits shown in methods A, A1, and A2 of this post post F6 Amplifier.
Old 17th August 2012, 02:20 AM   #833
Zen Mod's Avatar
F6 Amplifier
noise will be transposed via impedance of winding , not resistance
it will be noisier than simpler solutions , but I'm not seeing noise as major issue with CCS option
Old 17th August 2012, 02:22 AM   #834
At this point I am not advocating any particular circuit, but evaluating "out-of-the-box" alternative approaches. I thought that the ccs/dc-winding-resistance idea was worth looking at, nothing more.
Old 17th August 2012, 02:24 AM   #835
You are right about that. Will it be the reflected impedence of the front end driver? If so, the impedance might be fairly low.
Old 17th August 2012, 02:33 AM   #836
Zen Mod's Avatar
F6 Amplifier
nope
secondary inductance at any freq. covered with noise , so impedance
Old 17th August 2012, 12:37 PM   #837
Antoinel is offline Antoinel  United States
F6 Amplifier
Originally Posted by lhquam View Post
Power dissipation is the problem here. About 50mA current is required thru the transformer winding with an average of over 20 volts across the ccs when using 24V rails. The means 1 watt average power dissipation. We need a high power regulator or a ccs circuit which uses a power transistor for the main current.
TL783 is a high power positive voltage regulator [TO-220AB]. It has a published free air dissipation of 2 W at 25 Celsius, and 20 W on an adequate heat sink. The maximum recommended current is 0.7A at 125 V. Plenty!
Clearly lhquam you are chasing an experiment which you thought has value. As Mr. Pass will say: put it together and see what happens!
ZM: many methods to tan a skin to make leather. Each leather has its unique balance of valuable properties; an outcome of experiments.
Old 17th August 2012, 01:30 PM   #838
F6 Amplifier
My apology, the underlined is a mistake as written. [at] is the problem. The current [0.7A] times 125 V will violate the 20 W upper dissipation limit of TL783. Instead, operate the regulator at 0.7A such that the In-Out voltage differential is 28 VDC. Or operate the regualtor at an In-Out voltage differential of 120 V such that the output current is ~0.16A. Each of the above 2 situations do not violate the maximum dissipation constraint of 20W.
Old 17th August 2012, 05:45 PM   #839
The TL783 appears to have a problem for this application. The datasheet shows a graph of output current vs. in-to-out voltage. The current rapidly falls off below 25v. A Spice simulation for the part shows that below 12V in-to-out the part will not maintain 50mA current.
Old 17th August 2012, 05:46 PM   #840
buzzforb is offline buzzforb  United States
buzzforb's Avatar
How bout biasing schema like in BA1 output?
...Shape the sound , Man!
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
