F6 Amplifier - Page 82 - diyAudio
Old 16th August 2012, 08:07 PM   #811
Originally Posted by lhquam View Post
I found a problem with the LT3092, TL431, and LM134 regulators. The maximum voltage across the devices is 40V, which is not enough for an amplifier with 24 volt rails. Back to the drawing board.
Lhquam. TL783 High Voltage Adjustable Regulator. It has an input - output differential voltage = 125V.
Old 16th August 2012, 08:20 PM   #812
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
it's easy to put resistor in series with CCS , to eat some voltage and keep it safe
not that I'm advocating idea of putting DC through secondaries , even with totaled fluxes
one Jfet will need different bias voltage from another etc.
going simpler isn't simplest always
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 16th August 2012, 08:42 PM   #813
buzzforb's Avatar
I am going to try simple V divider this weekend. Cant argue with its simplicity.
...Shape the sound , Man!
Old 16th August 2012, 08:42 PM   #814
lhquam is offline lhquam  United States
A series resistor will have a constant voltage across it. When the amplifier output is near the lower rail, the lower current source will stop working. Similarly for the upper rail.
Old 16th August 2012, 09:05 PM   #815
Zen Mod's Avatar
nobody tells that you must tie lower CCS to mid-rail/output
you can fed it from upper rail
besides that , if you put cap across that additional resistor .........
anyway - try it , best way to learn .......
Old 16th August 2012, 09:15 PM   #816
buzzforb's Avatar
I was trying to uneerstand why it worked in BA output with similar rails, but could not work here.
Old 16th August 2012, 09:27 PM   #817
Zen Mod's Avatar
which BA , remind me
Old 16th August 2012, 09:43 PM   #818
buzzforb's Avatar
2
I am going to go listen now
Old 16th August 2012, 10:02 PM   #819
In my previous post, I should have been more explicit. The upper ccs is where the real problem is. Without using capacitors, I see no way to avoid the upper FET gate approaching the upper rail. There isn't any voltage above to connect the ccs to.
Old 16th August 2012, 10:04 PM   #820
Zen Mod's Avatar
@buzz
in BA2 OS , same as in F4 , bias gen is bootstrapped , so it's mid can swing above and below rails
@lhquam - same trick - bootstrap ; somewhere ; maybe across that additional resistor or ....
but - as I'm not for CCS through coil solution , I'll not give you complete schm
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
Copyright 1999-2017 diyAudio
