F6 Amplifier
F6 Amplifier
Old 5th August 2012, 05:52 PM   #561
kasey197 is offline kasey197
The Dastardly Dad of Three
F6 Amplifier
hi all,
Had time to fire up the iron again this weekend and wanted to run some tests in open loop (ie no NFB/degeneration) to see if i understood things correctly. Here are some observations, theory and then tests for some proof.
Setup:
Same schema as papas front end (just the tx+output stage). Supply rails +\- 24V. Output devices 2sk1058 hitachi latefts. Bias arrangement: 9V batteries with 5K pot to set voltage. The battery and pot bypassed by 220uF caps. Separate bias for top and bottom halves. Bias current set for 1.4A. Transformer was regular torodial power transformer. Stepup ratio approx 4x.
Results:
0.2V pk-pk in, 9.8V pk-pk out. Therefore gain = 49x. Given the tx gives us 4x, that means the fets are giving us approx 12.2X gain.
Theory:
Load R = 6.8R, therefore combined bottom n top half transconductance = 12.2/6.8 = 1.8 Siemens. Each fet therefore gives us 1.8/2 = 0.9 S transconductance. This seems to tie in with what i see from the hitachi datasheets.
Explanation:
Given the above, both top and bottom fets are acting in common source mode (despite the temptation to think about the top half as a source follower providing no voltage gain). If this hypthesis is true then both top and bottom halves provide equal amounts of gain. We can test this easily given the transformer coupling by just bypassing the top and bottom tx secondaries (ie in turn, each fet would see only the bias voltage, but no signal) individually and seeing the effect.
Results:
Both secondaries connected, trace 1. Output is 9.8V.
Top secondary bypassed, trace 2,. Output is 4.875V
Bottom secondary bypassed, trace 3. Output is 4.812V
Summary: So, the sum of the two halves individually = 9.7V vs 9.8V when theyre both connected. Seems close enough to suggest that the initial hypothesis that both halves act to provide equal amounts of gain (in common source) is correct.
Some other results/thoughts:
Warts n all open loop, the distortion performance seems pretty remarkable by comparison to a conventional complmenetary push-pull stage built. Here, (trace 4) you can see that theres zilch even harmonics and all were left with is 0.07% THD, almost all of it 3rd harmonic with very little higher order stuff.
The op stage needs some local feedback so as to reduce the miller effect on input capacitance which is very high. Having said that, the open loop freq response incl tx was quite usefully flat (trace 5). Seems to me that this would run quite respectably as-is w/o nfb if one could live with the HF rolloff and high o/p impedance. Addition of some feedback on this relatively linear stage will make for a pretty nice amp i think.....
Next steps while waiting (for the real F6):
a) Try the same local biasing arrangement i did last time but with lower impedance resistors (need to grab some WW low R pots tom)
b) Build the dual jfet input stage to see how that works....
I'm finding that part of the fun is in the journey .....
Old 5th August 2012, 05:57 PM   #562
F6 Amplifier
Also while we wait, anyone on this list sells the semisouth R100s ? Thought id order them in ahead...I usually get stuff from zhoufang but he seems to be away these last few weeks .....
Old 5th August 2012, 06:29 PM   #563
Antoinel is offline Antoinel  United States
F6 Amplifier
Originally Posted by kasey197 View Post
hi all,
Setup:
Results:
Theory:
Explanation:
Results:
Great work kasey. You've separated [and delivered] fact from fiction.
Old 5th August 2012, 06:43 PM   #564
lhquam is offline lhquam  United States
hi all,
Excellent. How are you driving the transformer? The suggested Jensen transformer is JT-123-FLPCH which has 4 windings with equal numbers of turns. Thus it must be run either 1:1 or 2:1. I suspect that it should be run 1:1 with the 2 primary windings paralleled, which will reduce the gain by a factor of 4 vs. your transformer configuration. That will not leave a lot for negative feedback. It also suggests that the degeneration resistors should be kept low in order to keep the transconductance as high as possible, but having the MOSFETS be thermally stable.
Old 5th August 2012, 07:03 PM   #565
F6 Amplifier
You have a fair point with the fets im using since they have low transconductance.... The r100s have more than 10 times as much transconductance so there should be PLENTY of gain end to end even with 2:1 step down tx (!) or the 1:1 ...
Re your first question, the test setup is driven direct by the hp 35665a signal analyzer which has a very low impedance..... Real world use is going to need the fet buffers ala f6 schematic. That's on the to-do list (eventually) after I try the local biasing n fb network
Old 5th August 2012, 08:01 PM   #566
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
F6 Amplifier
I sell the JFETs for less than Newark does. PM for details.
GB 2017 #2 Ends 12/3/2017 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards In Stock
Old 5th August 2012, 08:14 PM   #567
buzzforb is offline buzzforb  United States
buzzforb's Avatar
TeaBag is excellent to deal with. Much more prompt than I.
...Shape the sound , Man!
Old 5th August 2012, 08:25 PM   #568
generg is offline generg  Germany
generg's Avatar
F6 Amplifier
or me.....
thank you kasey197!
and the First Wtt is......a really First Class PSS Idea
Old 5th August 2012, 08:54 PM   #569
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 5th August 2012, 11:02 PM   #570
Zen Mod's Avatar
F6 Amplifier
Setup:
had some C in series with secondaries , to save them of DC ?
...... Seems close enough to suggest that the initial hypothesis that both halves act to provide equal amounts of gain (in common source) is correct.
yup
as I wrote - quasicomplementary is in function same as complementary ; with even greater symmetry between windings (which we can expect from signal xformer , comparing to crude mains one ) and , say , if we can use really dynamically matched (even best in situ , observing THD spectra ) outputs , we can expect even greater amount of suppression of even harmonics ; say that with some feedback that will be less critical than in case of OL .
having more than , say , 3-5mA through bias net is hardly of any benefit ; remember that you need to decouple gate from bias net with at least 10K , to avoid unnecessary loading of secondaries
then secondary's action will give enough AC mA for proper feed of gates
that's what counts , not brute force in bias net
anyway - did you observe near clipping action of tried OS ?
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 05:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 09:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 08:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 09:38 AM
F6 traw Pass Labs 7 2nd November 2007 08:09 PM
Copyright ©1999-2017 diyAudio
