F6 Amplifier
F6 Amplifier
Old 27th March 2014, 07:01 PM   #5661
aoc is offline aoc  Malaysia
Papa,
Back to back zener between gate and source i presumed? Also just curious why do you consider it leaky, looking at SS R100A specs, it is expected that the gate will draw 10mA with Vgs of 2.6V, R100A max gate fwd current is 220mA so at Vgs or 1.2V 0.5mA seems reasonable.
Alex
Old 28th March 2014, 02:55 AM   #5662
Update: I change R6 from 10k -> 4.7k and was able to bias idle current to the 1.5A i was targeting, it could still go higher, but i'm satisfied to start characterizing the amp. I don't have JFET buffers, plan on driving direct from my TVC for now.
On the O-scope i could see about 30mVpk-pk ripples from the supply (100Hz according to the FFT) with nothing connected to input or output. I built the PSU board from teabag with 22mF -> 0.27ohm -> 22mF || 22mF (mf = miliFarad) -> amp. i have yet to measure ripples on the supply with 1.5A loads, just trying to get a feel if it reasonable due to PSRR or its due to something else like grounding or the LED reference voltage needs a cap for smoothing.
If anyone else measured the output noise level on the output on their amp do share, just wondering if what i measured is reasonable. ofcourse 30mVpk-pk is just 10uW of power into 8ohms assuming the voltage level doesn't change.
Alex
Old 28th March 2014, 03:25 AM   #5663
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F6 Amplifier
As a rule my R100 parts have Gate current on the order of 1 to 20 uA
with a little more than an amp Drain to Source. I don't ship anything greater
than 30 uA, and that's after a few days burn in at temp.
At 20 uA, your drop would be 200 mV with 10K.
Old 28th March 2014, 06:43 AM   #5664
Nelson,
Thanks for the advice. I supposed I could back down my bias to 1A range as I notice the gate current don't rise much until I exceed 1.2A idle current. I can live lower power class A in my setup.
I only have 3 pairs of SS so I'll get the first channel working, second channel then revisit if the spare of SS is a better fit. Now only if I can buy another pair from someone
Alex
Sent from my C6903 using Tapatalk 2
Old 28th March 2014, 09:02 AM   #5665
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
ask Semisouthfan
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 28th March 2014, 10:08 AM   #5666
I backed down the bias to 1A and the gate current drop significantly, but not quite enough, still draws about 200uA. Guess I'll better swap to another pair if JFETs
Old 29th March 2014, 04:22 PM   #5667
Update: I swapped out the 2 JFETs (only one with high gate current) and replaced it with another set. Was able to bias to very high current if so desired (unintentionally turn too fast and current shot to 2.3A) back down current to about 1A idle current, measured output voltage offset, was 21V! Turn the offset trimpot P1 all the way to ground but no change in offset voltage at all. Measured gate current, new Q1 measures almost 1mA. Swapped out Q1 for there other good JFET from first attempt. Bias and offset voltage holding steady and nice. Good thing the Vgs measured by Teabag for both sets was very close, less than 0.1V delta. Phew will introduce audio signal next. I only have 1 pair of JFETs left. Hope that pair is fine.
Anyone with a pair to sell please pm me. I'll be hitting the usual suspects as well.
Alex
Old 29th March 2014, 04:38 PM   #5668
generg is offline generg  Germany
generg's Avatar
F6 Amplifier
yeah setting the bias pot is a bit dangerous, long time nothing and then very quick rise of the bias….
I had to take care of this always…..
and the First Wtt is......a really First Class PSS Idea
Old 15th April 2014, 09:11 PM   #5669
jugi63 is offline jugi63  Finland
What's this?! its a variable resistor.
Explanation: I needed a metod to easily test different degeneration resistor values (soundwise)and sadly the local store didn't have any smaller power resistors (2-3W) than 0.1 ohms. So I made a kind of a lader pot using 0.5mm copper wire. Copper wire resistance is 84.22 ohm/km (for 0.5mm dia) so each 30cm wire length between the switch pins gives about 0.025 ohms additional resistance to the value of R13 and R14. So now I can test the sound of the amp(s) with exact values of: 0.0 - .025 - .05 - .075 - .1 ohms. Will be interesting.
Soundwise thinking: I had the 10 ohm trimpots (P3 & P4) in place and listend for some time. But the problem was that the trimpots would not go totaly open (= zero resistance) so I was not sure how that affected the sound. I've now tried the amp bypassing the trimpots and output degeneration resistors (R13 &R14) but am not totaly satisfied with the sound. With the trimpots in, I got a setting with more flesh and voluminous timber - but also a little too undifiened bass. Without the pots and degenaration resistors the sound is more balanced and tunefull, but... also a little too dry. So now to try the ladder pots.
Old 15th April 2014, 09:44 PM   #5670
OllBoll is offline OllBoll  Sweden
I take it is insulated wire? If not then I guess you will have to be very careful none of the wires touch =)
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 05:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 09:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 08:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 09:38 AM
F6 traw Pass Labs 7 2nd November 2007 08:09 PM
