F6 Amplifier
F6 Amplifier
Old 7th November 2013, 10:46 PM   #5481
generg is offline generg  Germany
generg's Avatar
F6 Amplifier
Originally Posted by Zen Mod View Post
tower is temp switch
if temp in case is higher than wanted , it goes off
3 small caps - probably on mains etc.
don't waste time thinking of them - all you need is on published PS schm
Single Cap under the temp switch is the normal 0.0033 line cap, the two black parts over the temp switch are no "caps" but 4A mini fuses...... :-)
and the First Wtt is......a really First Class PSS Idea
Old 8th November 2013, 08:30 PM   #5482
generg's Avatar
F6 Amplifier
look at F5 PSU and you will find it...
Old 8th November 2013, 08:35 PM   #5483
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
vanished
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 8th November 2013, 08:37 PM   #5484
jugi63 is offline jugi63  Finland
Thanks Generg!
Ok, I won't... I think.
Here's the plan. Rounding up the parts still...
https://melaveikot-sporttisaitti-com...0SketchUP.jpeg
Old 8th November 2013, 08:37 PM   #5485
vanished
Had trouble addin the pic...
Old 8th November 2013, 08:40 PM   #5486
Zen Mod's Avatar
F6 Amplifier
I knew that .... but couldn't resist
Old 20th November 2013, 08:11 AM   #5487
Originally Posted by andreas w. View Post
I took this one
Seifert-Electronic - Products
Seifert KL-271 ; 300 x 150 x 83 mm
It's getting pretty warm
Andreas,
how much did you pay for yours? Here in Finland they are asking 83 euros a piece & 30 euros handling fees - and a 4 pcs minimum. Gets quite expensive...
Old 20th November 2013, 10:16 AM   #5488
andreasw is offline andreasw  Germany
For the F6 I bought the KL-271 for 60,- Euro (both) of a friend of a German community
In February we bought some Seifert heatsinks (400 x 200 x 83 mm) for other projekts and wie payed 75,- Euro.
But we picked them up (it's an one hour trip) and the amound was 12 pieces.
Old 20th November 2013, 10:29 AM   #5489
Ok, just checking... I wrote Seifert and it so happens they have a distributer here in Finland, so they forwarded the email here. I had a suspicion about the price and it seems I was right. The price is more than double here..(!)
I quess I'll be making more inquieries else where...
Thanks!
Old 26th November 2013, 02:01 PM   #5490
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
F6 Amplifier Send a message via Yahoo to vdi_nenna
Default R13 and R14 Power Dissipation
Can someone tell me the wattage value of R13 and 14? I searched and tried to calculate it, but the Ohm's calculations don't make sense.
Ohm's Law Wheel
If I use this Ohm's law wheel, it's R * I^2=.24w, is this correct? Doesn't sound like it is. What about the voltage?
23v^2 / R{.1} = 5290w? No way.
23 x 1.55 = 35.65w? No...
I thought Ohm's law was suppose to be easy?
What's missing? What's the relationship here?
Does something else need to be figured out before putting in the values into Ohm's law?
Looking at the F5 sense resistors, I see a 3w resistor.
Is 3-5w resistor close enough?
Hope this gives you good insight into the confused mind.
I build, therefore I am.
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
