F6 Amplifier - Page 505 - diyAudio
Old 24th July 2013, 05:29 PM   #5041
OllBoll is offline OllBoll  Sweden
Originally Posted by Nelson Pass View Post
If you are looking to have a current source (high output impedance) amplifier,
then it would work. If I were doing that, I would say you can eliminate R2
and run the primaries in series from input to ground.
Cool, Ideally I want a current source amp so that would work even better =)
Would it still have about the same high frequency rolloff as a vanilla F6 or would it be limited as if you remove the feedback in a vanilla F6?
Old 25th July 2013, 02:12 AM   #5042
The one and only
Nelson Pass's Avatar
Here are the response curves of an F6 with and without feedback:
Old 25th July 2013, 02:14 AM   #5043
The one and only
Here it is in GIF
Old 25th July 2013, 04:35 AM   #5044
The Dastardly Dad of Three
so nelson watt's new ? working on anything interesting ?
Old 25th July 2013, 05:47 AM   #5045
Here it is in GIF
Yes, I remember that curve from further back in the thread. It was the main reason why I didn't pursue a current source F6 further then. If I'm not mistaken the reason for it is the transformer, which is what made me have som wishful thinking that it would be possible to easily bypass the transformer since then the feedback could be removed without penalizing the roll off.
Is there any easy ways to extend the bandwidth without adding feedback? I guess you could hook up some resistors and caps to lower the gain before the transformer to something more uniform. In that case then my guesstimate would be a passive line level 50 khz first order highpass shorted by a large resistor would do it.
Old 25th July 2013, 03:08 PM   #5046
The one and only
My sheet currently shows about 40 amplifier projects and variations. Most
of them are interesting, and most of them will be constructed for analysis.
Old 25th July 2013, 03:11 PM   #5047
The one and only
You can give the output devices an active buffer. Usually if I'm looking for a
lot of bandwidth I go active.
Old 25th July 2013, 03:18 PM   #5048
buzzforb's Avatar
Slowin down, it seems
...Shape the sound , Man!
Old 25th July 2013, 04:11 PM   #5049
You mean something like this?
Old 25th July 2013, 05:03 PM   #5050
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
lower Jfet in both buffers is starved
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
Copyright 1999-2017 diyAudio
