F6 Amplifier
F6 Amplifier
Old 21st June 2013, 12:19 PM   #4661
Antoinel is offline Antoinel  United States
F6 Amplifier
Originally Posted by lhquam View Post
I received my F6CC Teaser boards and parts. Here is a picture of the build so far. Obviously the MOSFETs have not been yet attached with mica and grease. I am about ready for a smoke test.
This is a bench-test setup where the MOSFETs are attached using MOLEX connectors and elevated by a 1/4" aluminum plate which is attached to the heatsink with thermal grease and screws. This makes it easy to experiment with different MOSFETs be unscrewing them and readjusting the bias voltages. Also, using hex standoffs for power and output connections makes board removal easy in order to make component changes.
Will the heat sink be cooled by forced-air?
Old 21st June 2013, 01:32 PM   #4662
lhquam is offline lhquam  United States
Assuming roughly F5 power dissipation, ie. 65 watts/channel, the heatsink should be adequate for convection cooling. It is from HeatsinkUSA: 10.8" wide, 7" long, and 2.5" fin height. 10.080" Wide Extruded Aluminum Heatsink - HeatsinkUSA, LLC Store
Old 21st June 2013, 01:41 PM   #4663
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Have you considered a simple regulated cascode as a way of avoiding Rs? Would this allow a type of active degeneration of the cacode device, and with it, the fet it guards.
...Shape the sound , Man!
Old 21st June 2013, 02:08 PM   #4664
As I have repeatedly stated, with the transformer secondaries connected to the MOSFET source pins, there is no AC degeneration, and the source resistor only affects DC bias stabilization. Same in the F6.
What you are suggesting could be accomplished in a simpler manner using a DC current servo in the gate bias circuit. Here is an example of a design for a cascoded F5 with no AC degeneration using a current servo:
Old 21st June 2013, 02:25 PM   #4665
buzzforb's Avatar
way of avoiding Rs?
The F6 can be built without Rs affecting either AC degenration or DC bias. It would appear, that this is how Nelson chose to do it in his sample sent to 6moons. Clever control of the cascode could possibly accomplish this. I am new to the lingo, but i assume that a servo is the same as an error amplifier.
Old 21st June 2013, 02:58 PM   #4666
F6 Amplifier
Thanks lhquam for the valuable info.
Old 21st June 2013, 03:00 PM   #4667
F6 Amplifier
DC servo is a fascinating development; maybe a first to use an op amp in this thread or even the Pass Labs Forum.
Old 21st June 2013, 03:19 PM   #4668
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
thread most probably yes , forum not
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 21st June 2013, 03:37 PM   #4669
F6 Amplifier
A possible idea to stabilize the bias of the output stage will be to idle Q1 and Q2 at a lower current, and simultanously augment the needed total output current with [n] complementary current bootstraps; shown as bjts for example. This proposed circuit [attached] develops a constant voltage across Q1 and Q2 [your cascodes], and a simultaneous contant current flowing through them. This thinking was borrowed from US 4,107,619 which is STASIS[R] for the amps of Threshold Corp.
It is possible that this circuit may also function as a souped up F5!
Old 22nd June 2013, 03:02 AM   #4670
No smoke! The board layout appears to be fine, except that the pots are backwards wrt. clockwise increasing the relevant parameter (no big deal).
The overall bias current stability is fine, except that the output offset voltage drifts more than I would like. Is this problem related to the cascoded outputs? If so, there might be a simple 2-resistor solution based on negative feedback to the bias circuits.
The THD measurements are OK, but not as good as I am looking for. There is still a lot of tweaking to do.
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 05:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 09:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 08:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 09:38 AM
F6 traw Pass Labs 7 2nd November 2007 08:09 PM
