F6 Amplifier - Page 466 - diyAudio
Old 19th June 2013, 06:58 PM   #4651
generg is offline generg  Germany
generg's Avatar
My wife has given up smacking me...no good sign!
and the First Wtt is......a really First Class PSS Idea
Old 19th June 2013, 07:01 PM   #4652
Originally Posted by lhquam View Post
I am sure it will sound different, but:
  • The resistors from the source of the output FETs to the gates of the JFETs create global negative feedback.
  • The all of the feedback currents will be sensitive to the rail voltages thus degrade the PSRR.
Thanks lhquam for your analyses. Will this global NF lower output impedance like that in diyF5?
Old 19th June 2013, 07:47 PM   #4653
bnorrish's Avatar
AU-anon? For anyone (wives) who believes their life has been affected by someone else's audio obsession (addiction), either today or in the past.
Old 19th June 2013, 08:58 PM   #4654
lhquam is offline lhquam  United States
I would think so. You should run a simulation and see.
Old 19th June 2013, 09:05 PM   #4655
Thanks lhquam.
Old 20th June 2013, 03:39 AM   #4656
The one and only
Nelson Pass's Avatar
Yes, I think a regulated supply might come in handy.
Old 20th June 2013, 11:54 AM   #4657
An added complexity which is absent in diyF5.
Old 21st June 2013, 02:26 AM   #4658
I received my F6CC Teaser boards and parts. Here is a picture of the build so far. Obviously the MOSFETs have not been yet attached with mica and grease. I am about ready for a smoke test.
This is a bench-test setup where the MOSFETs are attached using MOLEX connectors and elevated by a 1/4" aluminum plate which is attached to the heatsink with thermal grease and screws. This makes it easy to experiment with different MOSFETs be unscrewing them and readjusting the bias voltages. Also, using hex standoffs for power and output connections makes board removal easy in order to make component changes.
Old 21st June 2013, 09:15 AM   #4659
buzzforb's Avatar
Looking good. Did you ever have any luck with dropping Rs. Using this technique. If so, I may try it with preamp I am playing with..
...Shape the sound , Man!
Old 21st June 2013, 09:20 AM   #4660
generg's Avatar
a clever solution to change the components....!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
Copyright 1999-2017 diyAudio
