F6 Amplifier - Page 441 - diyAudio
Old 6th June 2013, 09:01 PM   #4401
Originally Posted by lhquam View Post
Perhaps these posts are somewhat off-thread, but unless someone suggests a new thread, here they are:
Here are some Spice simulation resulted for the schematic shown in post #4367 F6 Amplifier. The plots are:
  • Harmonics vs. frequency at 1 watt into 8 ohms.
  • Harmonics vs. frequency at 10 watts into 8 ohms.
  • Harmonics vs. power at 1 kHz.
  • Harmonics vs. power at 7 kHz.
Note how H3 remains rather constant vs. frequency and H2 increases nearly linearly with frequency above 1 kHz. If one were to build a bridged ( balanced) amplifier from this in order to cancel most of H2, the result would even more impressive.
I will perform similar simulations without cascoding.
lhquam, of interest are OLG and the attendant power bandwidth.
Old 6th June 2013, 09:07 PM   #4402
lhquam is offline lhquam  United States
Originally Posted by generg View Post
No data lhquam!
Are you asking for numerical tabulations of the harmonics? I was assuming that the plots would be sufficient to see the overall behavior.
Old 6th June 2013, 09:10 PM   #4403
6L6 is offline 6L6  United States
6L6's Avatar
No data has posted.
Old 6th June 2013, 09:19 PM   #4404
Here are the plots for the cascoded version:
Old 6th June 2013, 09:20 PM   #4405
And here are the plots for the NON-cascoded version:
Old 6th June 2013, 11:22 PM   #4406
lhquam, is it possible to electronically subtract similar data for the two cases and display the differences?
Old 7th June 2013, 12:25 AM   #4407
Sure, that is possible, but I am not sure how much insight it would provide.
Old 7th June 2013, 12:43 AM   #4408
The Dastardly Dad of Three
cool stuff.... the pass cascode and a75 articles are worth a read here also. Lhquam - what output FET and voltage rails are you using - cannot quite make out from the charts even though im squinting
Old 7th June 2013, 01:40 AM   #4409
Go back to post #4367 F6 Amplifier.
The output FETs are FQA28N15 and FQA36P15. Rail voltages are 24V.
BTW: The upward bends above 16 watts in the Harmonics-vs-watts plots is due to approaching class B in the cascoded circuit. I should have added some additional wattage values between 16 and 25 watts to show this.
Old 7th June 2013, 01:47 AM   #4410
Botte is offline Botte  United States
Botte's Avatar
Final pages of 6moons review are up.
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
Copyright 1999-2017 diyAudio
