F6 Amplifier
F6 Amplifier
Old 22nd April 2013, 02:26 PM   #4141
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
You don t have to do the sound card thing kiven.
Your rigol scope can do FFT, with the math function
Old 22nd April 2013, 02:55 PM   #4142
generg is offline generg  Germany
generg's Avatar
F6 Amplifier
Originally Posted by kiven chen View Post
Read an article today, seem to say.
提示信息 - HIFIDIY论坛 - Powered by Discuz!
Hi Kiven Chen I am not allowed to enter these area in the Chinese forum.
Would be nice if you could do like dimkasta says......
and the First Wtt is......a really First Class PSS Idea
Old 23rd April 2013, 03:27 AM   #4143
kiven chen is offline kiven chen  China
You can try this address.
QQ??
Old 23rd April 2013, 03:35 AM   #4144
Comes to most tube amplifier will say their sense of even harmonic-rich fruity permeability adjectives
Comes to transistor amplifier has an odd harmonic distortion loud digital sound
Are divided into even and odd distortion of power amplifier distortion according to this comment is too general (is wrong) above is completely wrong
Today I have to correct everyone think even harmonics is even listening to mellow and odd harmonics is harsh is Concord 2 part 3 secondary harmonics part 2 should argue that odd sense of hearing is not good 3 should be deafening Concord
So I'm a tough---in fact, this is wrong! Both distortion is also not a poor sense of hearing and do not have a good sense of hearing can say 3 times and 2 times the same ear can not hear the difference
This is why? No credentials are affixed with a photo caption says harmonic distortion of power amplifier amplifier 2 harmonic Max -60dB (here not talking about total harmonic distortion is too general) or 0.1% already low distortion it simply in order to look more obvious bottom 10% distortion simulation I use to demonstrate
Green lines are fundamental secondary distortion components of Red 10% blue as a synthesis of waveforms
Old 23rd April 2013, 03:37 AM   #4145
Figure can be seen on -20dB a huge blue wave distortion
Just somewhat inclined and do not see there is a new wave form generation
Fact the wave ear cannot distinguish between it and the fundamental differences in the green line single-ended amplifier is prone to this kind of distortion
See third harmonic distortion
http://bbs.hifidiy.net/data/attachme...g4r7054rrg.png
Old 23rd April 2013, 03:44 AM   #4146
This huge distortion of the top and just makes the blue waveform peak becomes more round and no new waveform generation
The third harmonic distortion ear cannot distinguish the difference between it and the green of the original waveform before Xiao Buo easy output of any amplifier that
See below 4 harmonic distortion waveform
4 harmonic distortion and the top 2 times 3 times have significantly different waveforms can be seen now, twist-7 8, this is obviously a new waveform generation
Obviously listening ear for this waveform has a (separate) the fundamental ingredient is not outside of Concord had a b class-AB amplifier sound prone to distortion
See 5 waveforms
And the top four times as new wave is not explained
Class-AB amplifiers (note there's no b class) were most prone to distortion of the
6 waveforms
Ditto b class-AB prone
"Classmates" to ask like this didn't mention push-pull class a amplifiers may give rise to distortion of what the answer is: not here say that any distortion of the waveform is the infinite green fundamental to enlarge (precious)
Higher harmonics and 4 new waveforms appear 6 times as this is seriously affecting sense of hearing
Speaking of which, I think low harmonic distortion power amplifier harmonic distortion should be divided into 2 and 3 (does not affect the sense of hearing) and more than 4 times higher harmonic distortion and are not capped, will obviously affect the sense of hearing!
Even and odd harmonic distortion of power amplifier (here only on the harmonic distortion of power amplifier harmonic distortion sounds, and this is a difference does not talk about here) talk about its impact on the sense of hearing is clearly wrong!
Come to the conclusion that so-called even-order harmonic distortion of the amplifier (in fact, only 2 and 3----has been rarely go there because it is a class A amplification) is not the sense of mellow listening source actually has no effect on the sense of hearing is basically only there 4 times and higher harmonic presence reflects round (no high-frequency noise)
I mentioned this thread and this point is unity
中国音响DIY hifidiy 论坛 - Powered by Discuz! ... &extra=page%3D1
Old 23rd April 2013, 03:46 AM   #4147
It is posted at 提示信息 - HIFIDIY论坛 - Powered by Discuz!
Use online machine translation
Old 23rd April 2013, 09:20 AM   #4148
kasey197 is offline kasey197
The Dastardly Dad of Three
F6 Amplifier
Putting "Fruity Permeability" aside for one sec....
Some day this world will be a much smaller place - when machine translation worked on the fly and worked well. We spent so much on the human genome project, how about the powers fund the development of decent translation 'source-dictionaries' ...Imagine the contribution to sciences, the humanities, to travelling, chatting up birds ... to diy audio ...
Until then though, anyone who knows mandarin can help read the article and improve the translation above ? It looks intriguing ! Thanks kiven ....
Old 23rd April 2013, 10:01 AM   #4149
Every day I say is Mandarin, but this article does not help, because my English is so poor.
If you are interested in this, I try translation using a dictionary of single words. When I have time.
But there is little hope that, even if a single word translation estimate is also very difficult to understand.
Old 23rd April 2013, 10:12 AM   #4150
necplusultra is offline necplusultra  Canada
translate.google.com
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
