F6 Amplifier
F6 Amplifier
Old 7th April 2013, 12:14 AM   #4071
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I think that might have just let some air out, but I leav it to ZM for final word.
...Shape the sound , Man!
Old 7th April 2013, 12:26 AM   #4072
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
OK guyzzz
made it - proper balanced , either with 5-fiillar or 6-fillar
or , to not put a foot in BudP's territory - I don't care are they *-fillar or sectioned , as long they're good
I have no intention , same as I didn't had cojones any time before , to mess with Black Art .....
so , to put it in other way - proper balanced is possible with both 5 and 6 identical windings on one core
problem is - no so called summing feedback node ( two 18R resistors coneccted together and being one to another virtual gnd ) but instead of that - inverting feedback net must be used ;
but - as we already wrote before and BudP confirmed - everything is summing up through common core for all windings
are you guys interested in schmtcs ?
they're , shortly said , pretty much same as that previously posted one , except added one , or two , input modulating windings
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 7th April 2013, 12:46 AM   #4073
buzzforb's Avatar
Yup. I am gonna try to get all three in one layout.
Old 7th April 2013, 12:57 AM   #4074
Zen Mod's Avatar
F6 Amplifier
disclaimer(s) :
- sim made by Mighty ZM , so ........ be warned !
- best feedback values/ratio yet to be determined ..... preferably in vivo
somehow , I think I prefer more 5-windings iteration
gnd is , anyway , just state of mind
Old 7th April 2013, 02:36 AM   #4075
BudP is offline BudP  United States
BudP's Avatar
F6 Amplifier
If they must be truely balanced, inductance, capacitance and DCR then they must be fillar wound. Difference between 5 or 6 in hand is incidental to cost or size. What might be good to think on is how much inductance is really needed and how do the inductance's per node sum to the core, in the circuit? In addition, how linear does the inductance need to be from 20 Hz to 3.5 kHz, where 48% nickle core gives up and quits work?
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Old 7th April 2013, 02:46 AM   #4076
Zen Mod's Avatar
F6 Amplifier
considering Buzz's previous experience with your 4-way repeater , just add 5-th way
Old 7th April 2013, 03:07 AM   #4077
BudP's Avatar
F6 Amplifier
other than no complaints into the in box, I have no idea what buzz's experience has been, and do I not see 6 coil positions on the schematic? O are you referring to what I consider primary / secondary as the 5th repeater?
Old 7th April 2013, 03:08 AM   #4078
buzzforb's Avatar
Bud,
Im too dumb to know what to tell ya. If ZM can provide info, ill be buying some. If you gotta use more expensive cores, so be it. This amp is worth it to me.
Old 7th April 2013, 03:11 AM   #4079
buzzforb's Avatar
I just built more(possibly uneccesarily) complicated version, that sounds fantastic. It contains two of your transformers in a bridged setup. ZM has proposed two singl transformer versions. One is included in schema above. I would like to build it and prfer your work.
Old 7th April 2013, 03:22 AM   #4080
Zen Mod's Avatar
F6 Amplifier
to Budp:
I'm saying that , taking all in account , 5-coils version will be good enough if you can make it in same quality as those 4-coil ones , you already sent to Buzzforb
Buzz - in post #4074 , left one is 5-coil , right one is 6-coil iteration
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
