F6 Amplifier - Page 401 - diyAudio
Old 24th March 2013, 05:42 PM   #4001
Originally Posted by buzzforb View Post
Why would it act differently than solo F6?
What I wanted to say is: When you adjust each solo diyF6 in your setup for bias, ensure that it is operating open loop by cutting the feedback trace as close to the power output as possible. This is safest solution. An ther solution is to cut the trace after the 100 Ohm feedback resistor; such that it is connected [solely] to the bottom primary winding. This is a situation of a closed loop gain =1; which maybe problematic only when you are adjustring for bias etc.. I see this second situation [CLG=1] less desirable than OLG = xc. I am projecting possible problems at the tweaking stage. What is needed in the end is: With the bridge connected, both power outputs must settle at 0 VDc when power is turned on.
Old 24th March 2013, 06:24 PM   #4002
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
everything is safe if common feedback resistor is made of two halves , with common node connected to gnd , through setting procedure
effectively having two independent regular F6 channels with that arrangement
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 24th March 2013, 06:35 PM   #4003
buzzforb's Avatar
Thanks, mr ZM. Kinda like biasing f5x.
...Shape the sound , Man!
Old 24th March 2013, 06:50 PM   #4004
buzzforb and Zen Mod. I'm afraid that I am not on the same page you two are looking at. Nonetheless, I'm looking forward to the outcome.
Old 24th March 2013, 06:56 PM   #4005
buzzforb's Avatar
F5X -- the EUVL Approach - The Build Thread
Post 9
Old 24th March 2013, 07:12 PM   #4006
Thanks buzzforb. I simply took the initiative to do a PPA [potential problem analysis] for the startup of your bridged DIDO. You put a lot of time, effort, and $s to reach this advanced point. Better safe [for the equipment] than sorry will be my PPA to any DIYer.
Old 24th March 2013, 07:15 PM   #4007
Zen Mod's Avatar
F6 by Buzz , known as DIlDO F6
Old 24th March 2013, 07:24 PM   #4008
buzzforb's Avatar
The Mrs will be pleased. Thanks Antoinel for looking out. If I make magic smoke, I'll learn more cause I have to figure out why. I'll smoke some laterals first. Convenient bias level.
Old 24th March 2013, 07:45 PM   #4009
Impure thoughts!
Old 24th March 2013, 08:00 PM   #4010
Zen Mod's Avatar
guilty as charged
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
Copyright 1999-2017 diyAudio
