#381 |
Could the F6 be built with these devises: 2SK82 and 2SJ28 ?
I bought a pair of each a while back and need a project for them. Rush |
#382 |
probably too much complicated , at least comparing to intended SS ones
difference is that your's are depletion mode devices , needing negative voltage on gate (ref. source) for proper biasing , while SS SJEP are enhanced mode devices , needing positive voltage on gates (ref. source) for proper biasing meaning - for SS , all you need is few resitors , pots and caps for your's - you need at least one additional PSU rail , more negative than main -PSU
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#383 |
Sic58
#384 |
Ill get to it eventually with R085. As ZM has suggested, we dont know whats going on with bias and any tricks Nelson might be pulling. All smoke and mirrors for now.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#385 |
if you mean on depletion R085 - it's not worth complication , if you ask me
sometime is needed to draw a line in overcomplication (sez a guy who is Babelfishing Papa's simple amps in something much less simple )
#387 | ||
More Ideas: The first both topologies about http://www.ant-audio.co.uk/Theory/N-...0linearity.pdf shows a NMOS Power gain output PP stage (common source) and Current gain output PP stage (source follower). Is this also possible with a passive solution (i. e. by use of a driver transformer, as intended here) ?? Last edited by tiefbassuebertr; 27th July 2012 at 08:36 PM. |
#388 | |
#389 |
F4 power amplifier
F4 power amplifier and following the links above are to different pages in the F4 thread |
#390 |
| New F6 diy coming soon ? | Nounours18200 | Pass Labs | 37 | 31st August 2012 04:35 PM |
| Hi Vi F6 box | ioro | Multi-Way | 4 | 15th April 2012 08:27 PM |
| Whats happening with F6? | jugoslavija | Pass Labs | 1 | 1st November 2011 07:39 AM |
| Hi-Vi F6 | kkosiba | Multi-Way | 14 | 9th November 2007 08:38 AM |
| F6 | traw | Pass Labs | 7 | 2nd November 2007 07:09 PM |
