Old 13th February 2013, 03:20 PM   #3681
Originally Posted by buzzforb View Post
Too bad your not in NC anymore, you could listen to a whole range of FW clones. I could give subjective opinions, with measurements, but who would listen.
If you are suggesting that it would be interesting to see if certain measurements of amp function could be always related to specific sound perception I would have to agree most strongly. So I for one would listen to your views. Hard work though.
Reviews in magazines are usually centred on a particular model without trying to break down why those sounds are the way they are. Nelson seems to know how a particular circuit will sound but then he builds them so often he knows how to join the dots.
A question relating to how the F6 sounds when you are playing with the pots/phase thing: Is it possible in any amp to get maximum sense of space and depth in the soundstage whilst at the same time enjoying pinpoint accuracy of instrument position or do we always have to sacrifice one for the other?
It occurs to me that electrons have the same problem: momentum or position but not both at the same time.
Old 13th February 2013, 04:02 PM   #3682
buzzforb's Avatar
I'll start a new thread and start with F5T v2, as it is currently in position. I can have two other amps in functional cases, so ill finish my F6 and have it for direct comparison. Your welcome to enjoy my subjective entertainment.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 13th February 2013, 08:24 PM   #3683
Maybe Heisenberg had a F6
Old 17th February 2013, 11:50 AM   #3684
Dimitris
dimkasta's Avatar
Guys according to your experience with IRF flavor F6, what are its heatsink needs?
I have some modushop ones. The ones used in their 4U dissipante chassis.
(16,5cm x 20cm x 4cm at 0,31 C°/W)
Will one be enough for a single channel?
I m thinking probably not....
Old 17th February 2013, 12:11 PM   #3685
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
you already know the answer - two of these , per side , in their 4U/400 case , is adequate for common FW amp
5U is even better
whatever - add small lazy vent (12cm PC vent (Noctua is overkill and silent) either on some controller or just 6-7V ) and you're good
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 17th February 2013, 12:50 PM   #3686
Dimitris
dimkasta's Avatar
I did
Old 17th February 2013, 01:12 PM   #3687
cjkpkg is offline cjkpkg  United States
I am using a 3u 300mm deep sink per channel on my f6 build and use the same size on my moskido biased at about 1.2A per device.
I have one channel of the f6 running and biased at 1A per device. Let it sit for about 30 min and it was very warm but I could keep my hand on it. I will take a temp reading today.
Also I have a 4device per channel f5 and use the 4u 300mm deep sinks on it. Bias is set at about .5A per device and the sinks work well.
200mm on the 4u would be pushing it and you would probably struggle to reach 1A per device.
Old 17th February 2013, 01:21 PM   #3688
OllBoll is offline OllBoll  Sweden
While I don't have a F6 I've used the 3U 300mm also on Aleph J monoblocks. I can put my hand on them for 10+ seconds so according to Nelsons very scientific scale the temps should be fine =)
Old 17th February 2013, 02:05 PM   #3689
buzzforb's Avatar
I have had them on 10" x 4" 10.08 profile from heat sink USA with no real heat issues. Let um burn.
Old 17th February 2013, 03:32 PM   #3690
After idling for 30 minutes the temp of the heatsink was 124deg F. Bias settled down to 450mV on 0.50 ohm source resistors so 900mA per device.
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
Copyright ©1999-2013 diyAudio
