F6 Amplifier
F6 Amplifier
Old 27th July 2012, 01:10 AM   #351
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F6 Amplifier
covered
by Mighty Moi - several times in thread
it's 4 x 150 ohms , or 600CT:600CT
http://www.jensen-transformers.com/d...s/123flpch.pdf
as said previously - impedance is (same as ground ) very often just state of mind
it isn't 600 or 150 in this amp - think of reflected impedance from secondary to primary - that's the load for input buffer
by my experience , with lowish impedance category xformers , inductance ( more precise - enough of it ) is always most critical
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 27th July 2012, 01:11 AM   #352
eyoung is offline eyoung  United States
eyoung's Avatar
Is that 2 for stereo and 4 for Quadraphonic????
e
"Lead me not into temptation...I can find it myself."
Old 27th July 2012, 01:17 AM   #353
Zen Mod's Avatar
F6 Amplifier
and 8 of them for 7.1 system
buy 10 - so you can easily route signal to your car
Old 27th July 2012, 07:17 AM   #354
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
What is the main difference between the cores for driver transformers used for MOSFETs in switching applications (e.g. SMPS) and such for linear (audio) application like Jensen?
Here several URLs:
http://www.ferroxcube.com/news/gate%20drive%20trafo.pdf
http://www.ti.com/lit/ml/slup169/slup169.pdf
Pro Audio Design Forum • View topic - THAT1646 Current Booster and Transformer Driver
Transformer-driven SEPP output stage.
Old 27th July 2012, 07:38 AM   #355
Zen Mod's Avatar
F6 Amplifier
bandwidth dictates winding approach
SMPS is using one frequency
audio .........
Old 27th July 2012, 08:20 AM   #356
nicoch58 is offline nicoch58  Europe
humm to my car ?
really nice trafo ... jensen , 50% nickel , 38$
Old 27th July 2012, 08:41 AM   #357
Zen Mod's Avatar
F6 Amplifier
Originally Posted by nicoch58 View Post
.... , 50% nickel , 38$
you can beat that only with something like this (there are also 600ct:600ct types , looking exactly the same -all of them having toroid nickel core ) :
see more here : PAPA'S KOAN ....... was Papa's Surprise
same jobbies made by Tamura and WE are having price equaling their weight in gold
and they are plain and simple repeater coils , as called in Telephone Service duty
so - here is another tip - look for old repeater coils , and stash them in quantity .....
(in my previous life , we were using pairs of these (pair for stereo on sending end , pair on receiving end ) for transmission between concert venue and recording studio ; line was made of simple twisted solid core telephone cable, per channel )
Old 27th July 2012, 09:02 AM   #358
great!
Old 27th July 2012, 12:17 PM   #359
Antoinel is offline Antoinel  United States
F6 Amplifier
Let us consider experimenting with toroid power transformers; like kasey197 has been doing. For example the transformer by TRIAD VPT230-110. It is rated at 25 VA [$20 at Mouser; made in China]. It has 2 independent primary windings each meant for 115 VAc, and two independent secondary windings meant for 115 VAC. They are clearly labelled for phase by the color of the wires' insulation. Thus, it has the desired 1:1 transfer ratios, and is designed on purpose for large voltage swings which are needed to drive the FETs. It is over rated for this application [output current per secondary winding = 110 mA rms] which implies linear operation because the demand for current is low by the FETs.
The telephone repeater transformers may have low frequency limitations because they were designed principally to transmit voice. Their published bandwidth rating begins at ~300 Hz.
Old 27th July 2012, 12:43 PM   #360
Zen Mod's Avatar
F6 Amplifier
generally very good idea ,but you must consider that those Jensens aren't expensive
regarding repeater coils - each type demands testing
these which I pictured are flat 20-20
edit - in fact , they're flat from lower than 20Hz (if driven with lowish impedance ) and at least up to 50Khz , if memory serves me well
F6 AmplifierHide this!Advertise here!
New F6 diy coming soon ? Nounours18200 Pass Labs 37 31st August 2012 04:35 PM
Hi Vi F6 box ioro Multi-Way 4 15th April 2012 08:27 PM
Whats happening with F6? jugoslavija Pass Labs 1 1st November 2011 07:39 AM
Hi-Vi F6 kkosiba Multi-Way 14 9th November 2007 08:38 AM
F6 traw Pass Labs 7 2nd November 2007 07:09 PM
